Quote: vern it roll at least 5-10' after clearing. They don't give us much room that's for sure. Usually I just take it up to about 3k hold or a second and move forward...seemd like it wanted to stall so I gunned it more than usual. Still have the factory amp gauge hooked up, looks good.
Voltage at your amp gauge doesnt mean anything... check it at the pump and also at the ignition... is that old fuel in your tank... it sounds like its old fuel or it has water in it... could just be the ignition
