I can get the pump lower on the rail then the tank pickup but mounting it anywhere rear of the axle is just not possible- the pump is simply to big(I don't want people to see it and the lines hanging down from the rear of the car). The instructions say mount it vertical so it does not flood the pump housing but I just can't see that happening on the mild angle that I've pictured- there is no weep hole either. I know mounting it ahead of the tank is not the hot ticket but I don't think I have another option after looking under the car again
I thought about moving springs and exhaust around but I'm just not sure I want to go there or if it's worth it.
damn.
What about getting a different pump , something like an aeromotive that would easily mount in the area above the axle ?
