Quote: Maybe Moparts member 68HemiB will chime in, he's an xpert on "dual field" alternators and their inner workings
I know it's been almost two weeks, but I cannot let Mike down on this point.
Most knowledgeable folks on moparts will cringe when they see someone use the term posi when applied to a limited-slip differential installed in a Mopar.
Well, it's like fingers on a chalkboard to me when I read "dual field". An ISOLATED FIELD alternator as is being discussed here might have two field connections, but there is but a single field circuit inside the alternator.
