I am afraid that they are not going to find anything wrong and then I am back to step one on trying to figure out what is causing the ammeter/voltage fluctuations.
If it does come back with no issues, then I am planning on pulling one fuse at a time while watching the ammeter/voltage gauge to see if I can locate a circuit that clears it up. I was also thinking of buying a cheap stock alternator to test on the car too to see if there is any change.
Thanks for the replies.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
