Dude, i'm feeling horrible about this mess cause i feel like i talked you into switching over. i wish i had some solid help for you but i don't. could your gauge issue be a loose wire on the alt or a slipping belt? the 2 things should not be connected to each other(timiing too high and gauges going funky)
