And waiting 50 minutes between coats of clear? Really? I guess that's how it's done by professional painters on North Pole
That kind of advice can ruin months of someone's hard work. Because there are hundreds of clearcoats on the market with many options of reducers and hardeners for various temperatures and speeds.Many of them will react different to fresh coat after 20,30,40,50 or more minutes.So,unless you know which specific clear,reducer and hardener OP is using, I would keep that advice to yourself .
Once I shoot a clear coat I thin the remaining
amount and start shooting again... the voc need to
float up through... pretty hard when its dry
