Quote: Ron..the answer to your question is YES...stock,re-conditioned rods and all! Brad,the answer to your question is also YES! I'm still looking for that "magical" $500.00 carburetor! I REALLY do appreciate your very fair offer on the Demon RS...and you loaning it to me this past summer! THANK YOU! After reading Jeff's comment...looks like the 2.14's are staying put! After what I found when removing the rocker arm assembly....looks like a set of HEAVY DUTY pushrods are in order! I'll post a pic a little later this evening! I need to get some Play-Dough and check the piston-to-valve clearances to determine amount to mill for CR increase. Maybe 11.5 or 12:1...if allowable.
At those compression ratios I think your going to be getting away from pump gas(to me its not worth it)
