My ... you won't notice the difference anywhere except for your bank balance. Unless Jeff K says differently (and his experience obviously far exceeds mine), your combination isn't going to see a significant benefit from a increase in valve size.
And if you don't spend the additional $$$ on bigger valves, that'll leave you w/ that much more $$$ to buy a new carburator (unless you've already made that purchase).
