We like to put some basecoat on the car before hitting the paint booth. We thought this one was ready for the paint booth when looking at it in primer, but after some f8 paint we could still catch some flaws.
Some people say that doing this will cause paint adhesion problems afterwards, but that is not true, as long as you scuff the paint ENTIRELY once more after hitting the paint booth. Then you spray it with 2 more coats of base and then clear and it works just fine!
Also we like to do it this way because since its all covered already with the right shade of basecoat then it's a lot easier to get full paint coverage. Even if it it goes a bit thin inside the paintbooth in a spot that doesnt get as much paint as others it will still show the right color even if it got a teeny bit less paint.
