Re: My 69 HEMI Charger got paint!!!! :)
[Re: gygeneral]
#1102678
10/27/11 10:02 PM
10/27/11 10:02 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Great job, can you share how you achieved the slop look with the seam sealer?
Just urethane sealer, I bought those tubes that you have to apply with an aplicator gun. I cut the tip the biggest I could, and really applied it on REAL THICK. Then I just bought a brush and cut it in small pieces (as big as a barbers brush) and I brushed and spread the sealer. Its better to use a brush that has stiff bristles.
The key hear is to do it fast and not overdo it, you want to brush and push the sealer right in the middle to make the sealer get into the seam and leave the edges of the sealer just spread out so the spread and habve a "round" oozed off look on the sides. You want to brush just once, max twice and be done with it.
Thanks for the info, I'm doing a 71RR V code right now, and I'm at that point of applying the sealer.
Norm
Hey Norm, also, when you spread the sealer over the primer...you will probably think you didnt do it right, but its the contrast in colors (white sealer over the primer) that will get you thinkning that you didnt do a good job, and you will be tempted to spread the sealer some more and overdo it!!!...Just leave it, and when you spray it body color, it instantly looks good!!!!
So dont overdo it! Resist the urge to do so!!! LOL
