I'm just curious... what is the issue with the heads? What's the benefit of changing?
I want to know as well. Heads won't make that much difference on the final driveability you seek.
I agree with everyone else, you need to pick a proper cam, install and degree it and you should be fine. I drove my 440 car everywhere before I pulled it apart and it was no problem.
