Re: A833 stuck in gear
[Re: topside]
#1002244
05/30/11 10:13 AM
05/30/11 10:13 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Crrrraaap. I don't recall certain bolts/certain locations, but it's worth a try. On mine, I just loosened the bolts a bit, pried with a large screwdriver to hold the cover "up", then re-tightened the bolts. Probably grunted 'em to about 20 ft/lbs or so, didn't measure. DS will always feel "locked" with car in gear, if I understand you correctly. Have you adjusted the shifter, and were you using it to change gears? Does it have the correct forks & detents in it? Are the levers & rods installed correctly (not contacting/binding each other)?
All the bolts but 2 in the lower right corner have a SHOULDER , all of them but ONE are the same length , the longer one goes on the right side in the middle to align the cover.
Sounds like you still have a cover alignment issue .
