Yeah this is just great
OK so to clarify
1. The shifter is disconnected
2. I cannot move the 1-2 lever on the trans
3a. With the clutch in I can move the DS
3b. Since the DS will turn, then I know 3-4 and Reverse are in neutral
So tomorrow afternoon I will pull the plate and inspect the forks and report back (btw gear lube is so stinky!)
