Can a waterpump gradually go "bad"?
#986611
05/05/11 02:39 PM
05/05/11 02:39 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Still trying to sort through my high temps. Running around during 100 degree days here with my 440 results in temps pushing 200+. I'm not sure if that's too high, but it begs a question. My radiator is a new 3 core, the electric fan I've got on it does not cover the entire core (maybe 75 percent of it). I know this is a problem and while I await the funds for the mercedes fan and controller, I'd like to fix any other deficient areas. Currently running a 180* thermostat and an edelbrock waterpump (it's what came on the housing when I picked up the engine). Is this style of pump, with the cast vanes, more or less efficient than the stamped vane mopar style? Should I consider replacing it? Do they become less and less efficient as they age? I'm not sure how old this pump is. I know it's silly to ask, but is that possible? Thanks for any help
Re: Can a waterpump gradually go "bad"?
[Re: dOOc]
#986615
05/05/11 03:50 PM
05/05/11 03:50 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
At any speed will then motor then run at the temps the stat is at ?
Dipping into the NyQuil, Doc?
[Re: Kern Dog]
#986617
05/05/11 05:10 PM
05/05/11 05:10 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
Did YOU type that out ? ...
OK .... At any given car speed ...will the motor then run at the temp the stat is set at ?
BETTER ? ...
[Re: dOOc]
#986619
05/05/11 05:18 PM
05/05/11 05:18 PM
RapidRobert
You've got an excellent rad/good pump so I'm gonna assume that it's a low(er) speed prob so I'd say airflow & as you said non elec fan in the works plus a shroud/unobstructed grill
[Re: Kern Dog]
#986620
05/05/11 05:39 PM
05/05/11 05:39 PM
dOOc
Florida STAYcation
Oh DOC... I figured that you could take a joke as well as you can give them! Just having fun, you know.
FRANKENberri ... now if you look at that first post .... if you take-off the n on the first usage of the word THEN ... it makes BESTer sense.
[Re: Pat_Whalen]
#986621
05/05/11 09:06 PM
05/05/11 09:06 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Ive tried to figure out Docs replys for years.The scary thing.Im starting to decipher them.Rocky
Chrysler Firepower
[Re: therocks]
#986622
05/05/11 10:46 PM
05/05/11 10:46 PM
dOOc
Florida STAYcation
Yo Rocks .. it is good to hear that you have FINALLY laid that fattie down ...
[Re: Nino]
#986624
05/07/11 12:02 PM
05/07/11 12:02 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
The Problem is the Small Electric Fan Period . I have tryed many differant fan combonations and the best one is a factory seven blade with thermal clutch fan that has a 216 ending partnumber that fan pulls over 3500 cfm if you electric is under that the car will run hot . this fan can keep a 900 hp alum hemi cool in 90 deg weather it will work for you . second best fan is a 18 inch flex a lite seven blade fan . pulls tons of air at slow speeds and flatens out at high rpm . the both will work best with the shrouwd . but have used the factory with out shroud and still works good .
1969 Dodge Charger
1969 Dodge Superbee
