Can a waterpump gradually go "bad"? #986611
05/05/11 02:39 PM
05/05/11 02:39 PM
Mesa, AZ
P
Pat_Whalen Offline OP
super gas
super gas
P
Mesa, AZ
Still trying to sort through my high temps. Running around during 100 degree days here with my 440 results in temps pushing 200+. I'm not sure if that's too high, but it begs a question. My radiator is a new 3 core, the electric fan I've got on it does not cover the entire core (maybe 75 percent of it). I know this is a problem and while I await the funds for the mercedes fan and controller, I'd like to fix any other deficient areas. Currently running a 180* thermostat and an edelbrock waterpump (it's what came on the housing when I picked up the engine).
Is this style of pump, with the cast vanes, more or less efficient than the stamped vane mopar style? Should I consider replacing it? Do they become less and less efficient as they age? I'm not sure how old this pump is. I know it's silly to ask, but is that possible?
Thanks for any help
Re: Can a waterpump gradually go "bad"? [Re: Pat_Whalen] #986612
05/05/11 02:42 PM
05/05/11 02:42 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
I don't know , it either spins or it doesn't , unless the belt is slipping , you'd hear it , or the rotor falls off the shaft ???
Re: Can a waterpump gradually go "bad"? [Re: Pat_Whalen] #986613
05/05/11 03:17 PM
05/05/11 03:17 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Thanks for any help
Pick up one of those laser temp guns and check around on your motor. I got one at Autozone for around 30 dollars and verified that my gauge was off. Make sure you have no air pockets in the system as well. I have a 3 core aluminum rad with the alleged faulty Cat housing with a Napa replaement pump and can't get the car over 180 in traffic on a 100 degree day. You should go with a clutch fan and shroud.
Re: Can a waterpump gradually go "bad"? [Re: Pat_Whalen] #986614
05/05/11 03:46 PM
05/05/11 03:46 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
At any speed will then motor then run at the temps the stat is at ?
Re: Can a waterpump gradually go "bad"? [Re: dOrk !] #986615
05/05/11 03:50 PM
05/05/11 03:50 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Dipping into the NyQuil, Doc?
Re: Can a waterpump gradually go "bad"? [Re: Pat_Whalen] #986616
05/05/11 04:30 PM
05/05/11 04:30 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
The vanes can erode away and pump less.
Re: Can a waterpump gradually go "bad"? [Re: Kern Dog] #986617
05/05/11 05:10 PM
05/05/11 05:10 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Did YOU type that out ? ...
OK .... At any given car speed ...will the motor then run at the temp the stat is set at ?
BETTER ? ...
Re: Can a waterpump gradually go "bad"? [Re: dOrk !] #986618
05/05/11 05:16 PM
05/05/11 05:16 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Oh DOC... I figured that you could take a joke as well as you can give them! Just having fun, you know.
Re: Can a waterpump gradually go "bad"? [Re: dOrk !] #986619
05/05/11 05:18 PM
05/05/11 05:18 PM
You've got an excellent rad/good pump so I'm gonna assume that it's a low(er) speed prob so I'd say airflow & as you said non elec fan in the works plus a shroud/unobstructed grill
Re: Can a waterpump gradually go "bad"? [Re: Kern Dog] #986620
05/05/11 05:39 PM
05/05/11 05:39 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
FRANKENberri ... now if you look at that first post .... if you take-off the n on the first usage of the word THEN ... it makes BESTer sense.
Re: Can a waterpump gradually go "bad"? [Re: Pat_Whalen] #986621
05/05/11 09:06 PM
05/05/11 09:06 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive tried to figure out Docs replys for years.The scary thing.Im starting to decipher them.Rocky
Chrysler Firepower
Re: Can a waterpump gradually go "bad"? [Re: therocks] #986622
05/05/11 10:46 PM
05/05/11 10:46 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Yo Rocks .. it is good to hear that you have FINALLY laid that fattie down ...
Re: Can a waterpump gradually go "bad"? [Re: FuryUs] #986623
05/06/11 09:05 PM
05/06/11 09:05 PM
Pgh, PA
Nino Offline
Nino  Offline
Pgh, PA
I'm not saying that this is your problem, but it happened to me once. No usual warning signs -- no leaks from the weep-hole and no shaft-play. Finally pulled it, and the cupped portion of the vanes had completely worn away to the point that they weren't pumping at all, just spinning (the curve was completely gone). I used to have a picture of it somehwere...
Maybe check the temperature of the return hose to your radiator and see if it's hot/pumping... (it's not the most accurate, but I usually just use my hand and you can even feel when the thermostat opens).
1970 Dodge Coronet 1968 Barracuda FB 1970 Duster 1974 Dart 1977 Dodge Custom Van
Re: Can a waterpump gradually go "bad"? [Re: Nino] #986624
05/07/11 12:02 PM
05/07/11 12:02 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
The Problem is the Small Electric Fan Period .
I have tryed many differant fan combonations and the best one is a factory seven blade with thermal clutch fan that has a 216 ending partnumber that fan pulls over 3500 cfm if you electric is under that the car will run hot . this fan can keep a 900 hp alum hemi cool in 90 deg weather it will work for you .
second best fan is a 18 inch flex a lite seven blade fan .
pulls tons of air at slow speeds and flatens out at high rpm . the both will work best with the shrouwd . but have used the factory with out shroud and still works good .
1969 Dodge Charger 1969 Dodge Superbee
