Re: Anyone using 7/16 pushrods???
[Re: MR_P_BODY]
#925814
02/11/11 02:33 PM
02/11/11 02:33 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Thanks for the replys. Mr. P body, what block are you using and are the tapered 7/16 pushrods ones just as strong ?. I have never seen any of those. Thanks Mike
[Re: 70satelliteguy]
#925816
02/11/11 07:21 PM
02/11/11 07:21 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
How much open and closed spring pressure do you plan on running ?
What is the intended useage of this engine?
RIP Monte Smith
#925817
02/11/11 10:41 PM
02/11/11 10:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I sold all my B-1m/c stuff along with the mega block but I was going to use the 7/16 tapered instead of 3/8" straight because of high spring pressures(around 1000 or more open) but I clearanced the heads for them
[Re: MR_P_BODY]
#925818
02/11/11 11:35 PM
02/11/11 11:35 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
The bigger the pushrod, the better! Steve Morris, told me that he runs 9/16" pushrods in most of his larger engines. He said that he gained 43 hp from switching from 1/2" to 9/16" on his engine.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
[Re: Cudahlr]
#925819
02/11/11 11:48 PM
02/11/11 11:48 PM
Posts: 2,521 PA
moparacer
PA
I have 7/16 in mine with a low deck and Indy heads.
I think the only place I ran into problems was the end of the heads #1 #2 #7 #8 exhaust.
Had to clearance them a bit.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
