Anyone using 7/16 pushrods??? #925809
02/10/11 09:49 PM
02/10/11 09:49 PM
Penna
70satelliteguy Offline OP
Penna
Did you have to clearance your block to accomodate these? I am using a MP Mega block.
Thanks Mike
Re: Anyone using 7/16 pushrods??? [Re: 70satelliteguy] #925810
02/10/11 10:01 PM
02/10/11 10:01 PM
AndyF Offline
AndyF  Offline
Shouldn't have to clearance the block but you'll most likely need to whittle on the heads a bit.
Re: Anyone using 7/16 pushrods??? [Re: AndyF] #925811
02/10/11 10:04 PM
02/10/11 10:04 PM
Penna
Penna
Thanks Andy, how about clearance problems with solid body Comp roller lifters ?
Mike
Re: Anyone using 7/16 pushrods??? [Re: 70satelliteguy] #925812
02/10/11 11:00 PM
02/10/11 11:00 PM
Mike
I switched my 527 bracket motor to Manton 7/16 ball and cup from 3/8 ball and ball(switch heads and rockers) I had to trim the 440-1 heads with the 7/16 pushrods, didn't need to with the 3/8 pushrods on the SR heads Put them in and check for rubbing Both sets of rockers,T&D and Harland Sharps are 1.65 ratio so that does play a part in the pushrods rubbing
Re: Anyone using 7/16 pushrods??? [Re: 70satelliteguy] #925813
02/10/11 11:19 PM
02/10/11 11:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt have to touch the block for 7/16 tapered
PRs but had to remove a ton of material from my B-1M/Cs
Re: Anyone using 7/16 pushrods??? [Re: MR_P_BODY] #925814
02/11/11 02:33 PM
02/11/11 02:33 PM
Penna
Penna
Thanks for the replys.
Mr. P body, what block are you using and are the tapered 7/16 pushrods ones just as strong ?. I have never seen any of those.
Thanks Mike
Re: Anyone using 7/16 pushrods??? [Re: 70satelliteguy] #925815
02/11/11 07:19 PM
02/11/11 07:19 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Although you can make 7/16 pushrods work on INDY heads, it gets tight and takes lots of grinding. Unless you are just running insane spring pressure, usually a set of 3/8 pushrods with a .120 wall will do the trick.
Monte
Re: Anyone using 7/16 pushrods??? [Re: 70satelliteguy] #925816
02/11/11 07:21 PM
02/11/11 07:21 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
How much open and closed spring pressure do you plan on running ?
What is the intended useage of this engine?
RIP Monte Smith
Re: Anyone using 7/16 pushrods??? [Re: 70satelliteguy] #925817
02/11/11 10:41 PM
02/11/11 10:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks Mike
I sold all my B-1m/c stuff along with the mega block
but I was going to use the 7/16 tapered instead of 3/8"
straight because of high spring pressures(around 1000
or more open) but I clearanced the heads for them
Re: Anyone using 7/16 pushrods??? [Re: MR_P_BODY] #925818
02/11/11 11:35 PM
02/11/11 11:35 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
The bigger the pushrod, the better! Steve Morris, told me that he runs 9/16" pushrods in most of his larger engines. He said that he gained 43 hp from switching from 1/2" to 9/16" on his engine.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: Anyone using 7/16 pushrods??? [Re: Cudahlr] #925819
02/11/11 11:48 PM
02/11/11 11:48 PM
PA
moparacer Offline
moparacer  Offline
PA
I have 7/16 in mine with a low deck and Indy heads.
I think the only place I ran into problems was the end of the heads #1 #2 #7 #8 exhaust.
Had to clearance them a bit.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Anyone using 7/16 pushrods??? [Re: moparacer] #925820
02/11/11 11:56 PM
02/11/11 11:56 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Running 7/16 in my R5 no clearancing required. Totally different animal as well....
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Anyone using 7/16 pushrods??? [Re: 70satelliteguy] #925821
02/12/11 12:46 AM
02/12/11 12:46 AM
Thanks Mike
Mike, I'm not Mr Pbody but here is a picture of a 7/16 single tapered pushrod on the right, straight 7 1/6 in the middle and a 3/8 on the left side(looking down at them ) I tried using 8 7/16 single tapered to avoid trimming the heads on the intake sides, it didn't work The 440-1 heads use a offset intake rocker and I didn't want to change the intake rollers to offsets so I tried the single tapered pushrods instead, that didn't work either I ended up using them on the exhaust sides and used the straight .095 wall x 7/16 diameter on the intakes BTW, the single tapered I ordered are .167 wall on the straight 7/16 part and end up being .120 at the 3/8 tapered ends IHTHs
Re: Anyone using 7/16 pushrods??? [Re: Cab_Burge] #925822
02/12/11 02:33 AM
02/12/11 02:33 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I run 3/8 intake 7/16 exhaust stock block and b1 heads. But like mr body said, had to remove tons of material from the heads
Re: Anyone using 7/16 pushrods??? [Re: joshking440] #925823
02/12/11 07:57 AM
02/12/11 07:57 AM
virginia
572stealth Offline
572stealth  Offline
virginia
any real world gains by switching to thicker/larger pushrods? I have .080 wall 3/8 and was thinking of going to .135 wall 3/8. B1MC heads with 350 seat and 920 open.
Re: Anyone using 7/16 pushrods??? [Re: 572stealth] #925824
02/12/11 10:35 AM
02/12/11 10:35 AM
Penna
Penna
Thanks all for the reply's and for the pictures CAB !
I am changing roller cams on my 572 with the 572-13 heads. The spring pressures I am changing to are right with Mr. P body's are at 1000. I had been using 3/8 .080 pushrods with my other cam( 800 +) pressure but Chuck at Best Machine suggested going with the better springs and pushrods. He also suggested the tapered pushrods should help if I run into problems with the head clearance.
Thanks Mike
Re: Anyone using 7/16 pushrods??? [Re: 70satelliteguy] #925825
02/13/11 12:21 PM
02/13/11 12:21 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I just mocked up my mega block which previously had 3/8" pushrods. There were slight witness marks at the very top of the inner lifter valley. My 7/16" tapered pushrods fit. Though they were very close. A little grinding was all that was needed. The heads needed a little also. I have -1s
Doug
Re: Anyone using 7/16 pushrods??? [Re: 572stealth] #925826
02/13/11 01:42 PM
02/13/11 01:42 PM
I switch pushrods on the dyno my bracket motor when it had the SR heads and T&D rockers arms on it. I had a set of Smith Bros 3/8x.083 that they custom made for the motor(I wanted thicker but they insisted that .083 was more than enough for 275 lbs and 680 lbs openedOne of them broke in the middle during a dyno pull ) that I ended up replacing (after I fixed the motor) during another dyno session. I switch from the .083x3/8 Smiths to a set of .120 wallx3/8 diameter sereis 3 Mantons with no other changes, the motor made 8 HP more and the peak HP RPM went up 300 RPM I know there is more HP and valve train benifits in better pushrods than most people think BTW, you might want to try a set of 7/16 x.095 if they will fit
Re: Anyone using 7/16 pushrods??? [Re: Cab_Burge] #925827
02/14/11 03:43 AM
02/14/11 03:43 AM
Canada BC
Steve Barton Offline
Canada BC
Just wondering if any one has used the Comp Hi Teck push rods. I'm building an R3, Indy heads 360-2 with a bullet cam 700 valve lift. heads and cam cam from ryanj ?
Homepage Pic's http://www.bluemelon.com/dodgeman/ Steve. New best 1.40 60' 9.99 Et 132.8 mph
