Re: 68 383 Formula S now 411" B with Borg/Warner S480
[Re: CUUDAK]
#905318
02/14/11 09:32 PM
02/14/11 09:32 PM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
Got 1 side of the "Carl-TRAKS" installed today after installing the Energy Suspension bushings into the springs.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
[Re: CUUDAK]
#905321
02/15/11 06:56 PM
02/15/11 06:56 PM
CUUDAK
HEMPSTEAD TX
Wow!! Hotside is done!! I will have to do a little hammer & dollying to the lower radiator support to straighten out where I rolled the lip. Now I need to figure out how to mount the wastegate. I am going to put it into the merge just below the T6 flange. Now I have a question, I am screwed as to where I wanted to put it in the prior pics. Can I 90* off the flange/merge area or does the exhaust have to flow directly into the wastegate?
[Re: CUUDAK]
#905323
02/16/11 04:07 PM
02/16/11 04:07 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It's best to have it in a natural flow pattern but it will still work pointed off in some funky direction.
[Re: feets]
#905324
02/16/11 06:08 PM
02/16/11 06:08 PM
CUUDAK
HEMPSTEAD TX
I guess the only Bad would be the performance of the Hallman manual boost controller eh? Wouldn't be as accurate I guess.
[Re: CUUDAK]
#905325
02/16/11 06:33 PM
02/16/11 06:33 PM
Posts: 121 mid-mich
turboplymouth
mid-mich
What size gate? Mine is a 50mm, teed into crossover and d.p. I've never noticed any creep or spikes.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj.
9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
[Re: turboplymouth]
#905328
02/21/11 08:38 PM
02/21/11 08:38 PM
CUUDAK
HEMPSTEAD TX
Wastegate found its spot!! Guess I will bring the dump over the bracket and back into the dp.. A few pics,
[Re: CUUDAK]
#905330
02/24/11 07:30 PM
02/24/11 07:30 PM
Posts: 121 mid-mich
turboplymouth
mid-mich
Better late than never. Looks like yours is bout like mine, off the crossover anyway.
[Re: turboplymouth]
#905332
02/24/11 10:19 PM
02/24/11 10:19 PM
CUUDAK
HEMPSTEAD TX
Cool! That is about the only place I could put it without adding alot more pipe.
Notice you have wrap! I am wondering how well it works??? I bought the DEI Titanium wrap with the black silicone spray. Hopefully 100 feet of the 2" will cover my hotside and dp.
Still waiting on rods so I unboxed the new gas tank and started cutting 2" holes for the sump. Should get that done in the morning. Then I will start running the fuel line and install the A1000 and filter. THEN, I need to figure out where all the msd stuff is gonna go as well as the Aeromotive pump controller.
