Page 4 of 10 1 2 3 4 5 6 9 10
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: turboplymouth] #905315
02/14/11 03:57 PM
02/14/11 03:57 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Awesome. Thanks!
No problem!!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905316
02/14/11 07:03 PM
02/14/11 07:03 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Someone stole your left front tire!
- Stu Harmon
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: feets] #905317
02/14/11 09:31 PM
02/14/11 09:31 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Thats what happens around here if they sit too long..
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905318
02/14/11 09:32 PM
02/14/11 09:32 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Got 1 side of the "Carl-TRAKS" installed today after installing the Energy Suspension bushings into the springs.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905319
02/14/11 09:33 PM
02/14/11 09:33 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
13
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905320
02/14/11 09:34 PM
02/14/11 09:34 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
14
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905321
02/15/11 06:56 PM
02/15/11 06:56 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Wow!! Hotside is done!! I will have to do a little hammer & dollying to the lower radiator support to straighten out where I rolled the lip. Now I need to figure out how to mount the wastegate. I am going to put it into the merge just below the T6 flange.
Now I have a question,
I am screwed as to where I wanted to put it in the prior pics. Can I 90* off the flange/merge area or does the exhaust have to flow directly into the wastegate?
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905322
02/15/11 06:58 PM
02/15/11 06:58 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
15
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905323
02/16/11 04:07 PM
02/16/11 04:07 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It's best to have it in a natural flow pattern but it will still work pointed off in some funky direction.
- Stu Harmon
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: feets] #905324
02/16/11 06:08 PM
02/16/11 06:08 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
I guess the only Bad would be the performance of the Hallman manual boost controller eh? Wouldn't be as accurate I guess.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905325
02/16/11 06:33 PM
02/16/11 06:33 PM
mid-mich
turboplymouth Offline
mid-mich
What size gate? Mine is a 50mm, teed into crossover and d.p. I've never noticed any creep or spikes.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj. 9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: turboplymouth] #905326
02/16/11 08:30 PM
02/16/11 08:30 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Gotta pic?
Mine is a 60mm with a 7lb spring. I tested it to 30 p.s.i. with the Hallman MBC from around 5 lbs to 30.. Mine will 90 off the merge pipe and turn a gradual 90 to the wastegate. Right where the alternator goes.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905327
02/17/11 08:49 PM
02/17/11 08:49 PM
mid-mich
mid-mich
I'll snap some pics.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: turboplymouth] #905328
02/21/11 08:38 PM
02/21/11 08:38 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Wastegate found its spot!! Guess I will bring the dump over the bracket and back into the dp.. A few pics,
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905329
02/21/11 08:41 PM
02/21/11 08:41 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
16
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905330
02/24/11 07:30 PM
02/24/11 07:30 PM
mid-mich
mid-mich
Better late than never. Looks like yours is bout like mine, off the crossover anyway.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: turboplymouth] #905331
02/24/11 07:31 PM
02/24/11 07:31 PM
mid-mich
mid-mich
2
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: turboplymouth] #905332
02/24/11 10:19 PM
02/24/11 10:19 PM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
Cool!
That is about the only place I could put it without adding alot more pipe.
Notice you have wrap! I am wondering how well it works???
I bought the DEI Titanium wrap with the black silicone spray. Hopefully 100 feet of the 2" will cover my hotside and dp.
Still waiting on rods so I unboxed the new gas tank and started cutting 2" holes for the sump. Should get that done in the morning. Then I will start running the fuel line and install the A1000 and filter. THEN, I need to figure out where all the msd stuff is gonna go as well as the Aeromotive pump controller.
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905333
02/25/11 02:41 AM
02/25/11 02:41 AM
HEMPSTEAD TX
CUUDAK Offline OP
CUUDAK  Offline OP
HEMPSTEAD TX
I got this today. I'm sure this will keep the underhood temp down with the help of the VHT.
http://cgi.ebay.com/ebaymotors/ws/eBayIS...RK%3AMEWNX%3AIT
Re: 68 383 Formula S now 411" B with Borg/Warner S480 [Re: CUUDAK] #905334
02/25/11 07:50 AM
02/25/11 07:50 AM
mid-mich
mid-mich
I used it more or less to keep heat off of surrounding items (fan, rad. hose, etc.). Works great for that. I was hoodless last year, but I can tell it will definatly keep under hood temps down. Only have it on my crossover now, may wrap my headers and d.p. after I get the hood on.
