Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: Project Bad Demeanor [Re: Hitman340] #864458
12/04/12 11:50 PM
12/04/12 11:50 PM
Out West
408strokerdart Offline
Out West
Thanks guys.
Kenny, That is a glass hood with a carbon wrap.This is something I offer at my shop.
Thanks for the good info Brian. I will be sure to give that a close look. If I run into a issue I may be asking for some of your measurements to compair befor I call them. Thanks again!!!
Just let me know if you need anything.
Re: Project Bad Demeanor [Re: 408strokerdart] #864459
12/05/12 02:35 PM
12/05/12 02:35 PM
Baltimore,MD
lowbudget Offline
mopar addict
lowbudget  Offline
mopar addict
Baltimore,MD
Not to bust your bubble Jeff, but I see a problem....maybe. That is the same transmission I run. They forgot to put the "spacer" between the bellhousing and trans case on mine. They made a run of sb mopar bells that were to short and they make it up with a spacer. Now, maybe you have a newer bellhousing since they said they would correct it at their next run of castings. Just check it out....caused me some grief and took lots of measurements to find out it was not my mistake. ATI kept saying I didn't have the coverter in all the w
ay.
Thats hilarious, I delt with them over this same issue over 2yrs ago. The very first "adapter" is currently on my car. You would think they would have a clue by now
Re: Project Bad Demeanor [Re: lowbudget] #864460
12/05/12 03:17 PM
12/05/12 03:17 PM
Out West
Out West
ay.
Mine showed up just like the picture Jeff posted....no spacer. I about tore my hair out trying to figure out what I was doing wrong. With the spacer it went without a hitch.
Re: Project Bad Demeanor [Re: lowbudget] #864461
12/05/12 03:32 PM
12/05/12 03:32 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
You and Brian have me confused what didn't fit? I just got the same trans w a mopar sb bell and all worked and fit great...i just had to make a trans crossmember to work w it
Re: Project Bad Demeanor [Re: fishy340] #864462
12/05/12 06:48 PM
12/05/12 06:48 PM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
The issue with Lowbudgets car and a few others was ATI cast their small block mopar bellhousings for the powerglide supercase 3/4" too short. Took me 3 months of back and forth with ATI until they finally listened to me and rechecked there measurements and realized it was too short. So they fabbed up a 3/4" spacer between the bellhousing and the case to fix the issue. They haven't made a new run of those bellhousings yet that I know of, because im supposed to be getting one when they do. They want to sell all the short ones before they make new ones and its not like SBM to powerglide bellhousings are something they sell alot of.
LBSR
Re: Project Bad Demeanor [Re: fishy340] #864463
12/05/12 07:15 PM
12/05/12 07:15 PM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
dont how yours worked unless your running a midplate of some sort. Without the spacer I couldn't even get the bellhousing to mount up to the block with the converter in.
LBSR
Re: Project Bad Demeanor [Re: Bill_LBSR] #864464
12/05/12 08:03 PM
12/05/12 08:03 PM
Out West
Out West
I agree. Maybe you can measure the total length of your bellhousing? If it fit (and there is no spacer between the bell and trans case) then they might have fixed them. I would like to have one without having to use a spacer....not sure ATI would be quick to let everyone know it is fixed and they are ready to hand out free bellhousings.
Re: Project Bad Demeanor [Re: Bill_LBSR] #864465
12/05/12 08:09 PM
12/05/12 08:09 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Mine came w a spacer for the crank...the overall lengh of the glide is shorter but i was gonna have crossmember made to take care of that.The converter and trans bolted in perfect and fyi i got my bellhouseing about 5 months ago so maybe i got a.newer one. Thankyou guys
Re: Project Bad Demeanor [Re: 408strokerdart] #864466
12/05/12 08:10 PM
12/05/12 08:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Boy,
I read threads like this and truly wonder why the Mopar Gods ever saw fit to produce big blocks
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Project Bad Demeanor [Re: 408strokerdart] #864467
12/05/12 08:13 PM
12/05/12 08:13 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Brian this weekend ill get in my trailer and see if i can get a good measurement for you guys.
Re: Project Bad Demeanor [Re: 408strokerdart] #864468
12/05/12 08:38 PM
12/05/12 08:38 PM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
I'll have to give them a call and see. I figure a free bellhousing is the least they could do for me after doing their R&D work and figuring out the problem for them..lol
LBSR
Re: Project Bad Demeanor [Re: B3422W5] #864469
12/05/12 08:46 PM
12/05/12 08:46 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Boy,
they were created to keep weight on the nose and the wheels down lol
Re: Project Bad Demeanor [Re: Hitman340] #864470
12/08/12 05:54 PM
12/08/12 05:54 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Just want to post a couple of pictures for Brett.
Ritter 420
Re: Project Bad Demeanor [Re: S/ST 3040] #864471
12/08/12 05:55 PM
12/08/12 05:55 PM
S/ST 3040 Offline
S/ST 3040  Offline
Re: Project Bad Demeanor [Re: S/ST 3040] #864472
12/09/12 01:03 AM
12/09/12 01:03 AM
Niles, Michigan
Hitman340 Offline OP
Niles, Michigan
Looks real nice so far Vic.Only 25 or 30 hrs more and it will be all done. { The Intake that is }
Re: Project Bad Demeanor [Re: Hitman340] #864473
12/09/12 10:32 AM
12/09/12 10:32 AM
S/ST 3040 Offline
S/ST 3040  Offline
Thanks. I think my port work would be more effective if we could add a
3/4" bead of weld where the carburetor pad meets the runners.
Re: Project Bad Demeanor [Re: S/ST 3040] #864474
12/09/12 12:46 PM
12/09/12 12:46 PM
Niles, Michigan
Niles, Michigan
If thats what you want I will get it done and get it back to you.
Re: Project Bad Demeanor [Re: Hitman340] #864475
05/29/13 10:15 PM
05/29/13 10:15 PM
Niles, Michigan
Niles, Michigan
Now thinking about a carbon fiber wing.
Pistons are ordered and engine has been mocked up and chassis has a new cert tag. I do not want to set out another year!
Re: Project Bad Demeanor [Re: Hitman340] #864476
05/29/13 10:27 PM
05/29/13 10:27 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Dare I ask which block?
Re: Project Bad Demeanor [Re: Hot 340] #864477
05/29/13 10:41 PM
05/29/13 10:41 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
