Quote: You and Brian have me confused what didn't fit? I just got the same trans w a mopar sb bell and all worked and fit great...i just had to make a trans crossmember to work w it
dont how yours worked unless your running a midplate of some sort. Without the spacer I couldn't even get the bellhousing to mount up to the block with the converter in.
