Quote: You and Brian have me confused what didn't fit? I just got the same trans w a mopar sb bell and all worked and fit great...i just had to make a trans crossmember to work w it
dont how yours worked unless your running a midplate of some sort. Without the spacer I couldn't even get the bellhousing to mount up to the block with the converter in.
I agree. Maybe you can measure the total length of your bellhousing? If it fit (and there is no spacer between the bell and trans case) then they might have fixed them. I would like to have one without having to use a spacer....not sure ATI would be quick to let everyone know it is fixed and they are ready to hand out free bellhousings.
