Re: 68 DART
[Re: never2ready]
#854515
11/15/10 12:07 PM
11/15/10 12:07 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
68 CUDA AND DART HAVE THE SAME WHEEL OPENING I GUESS? THANKS
No, they are different. The Dart has a more flat slab side. Usually a 245/60/15 is about the widest tire for stock or lowered ride rear height 67-69 Darts.
If you jack up the rear, roll fender lips, and move springs in, you can fit more. I don't know exactly on that though.
Re: 68 DART
[Re: never2ready]
#854518
11/15/10 02:42 PM
11/15/10 02:42 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I WAS GOING TO USE THE OFF SET SPRING HANGERS. I DIDN'T NO IF THAT WOULD HELP OR NOT.
How come you weren't able to find the caps lock for your log in but you seem to have it well used for your topic and replies ???
Re: 68 DART
[Re: JohnRR]
#854519
11/15/10 02:46 PM
11/15/10 02:46 PM
Posts: 2,757 Gilbertsville, PA 19525
Pntastar69
Re: 68 DART
[Re: Pntastar69]
#854520
11/15/10 04:14 PM
11/15/10 04:14 PM
JohnRR
U.S.S.A.
Re: 68 DART
[Re: never2ready]
#854521
11/15/10 06:08 PM
11/15/10 06:08 PM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
I made a new front spring perch and located it next to frame rail, otherwise the tires wouldn't clear the springs. I used the offset shackles on the rear too.
Re: 68 DART
[Re: Mopar Grandpa]
#854522
11/15/10 06:23 PM
11/15/10 06:23 PM
JohnRR
U.S.S.A.
I assume one would have to move the perchs welded to the rear housing ?
Re: 68 DART
[Re: JohnRR]
#854523
11/15/10 06:52 PM
11/15/10 06:52 PM
Mopar Grandpa
Sebring, Florida
Yes, that is correct. However, all my modifications were done prior to locating the perches on the housing as I bought a new housing and the perches were shipped loose.
