68 DART #854512
11/15/10 11:38 AM
11/15/10 11:38 AM
N
never2ready Offline OP
N
STOCK TUBS. HAS ANYBODY TRIED TO USE A 275-60 TIRE ON A 7" WHEEL ON REAR OF 68 DART? THANKS FOR YOUR HELP.
Re: 68 DART [Re: never2ready] #854513
11/15/10 11:52 AM
11/15/10 11:52 AM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
I'm running 275-60's on an 8" wheel on my 68 Barracuda but had to move the springs in by about an inch.
Re: 68 DART [Re: never2ready] #854514
11/15/10 11:57 AM
11/15/10 11:57 AM
N
N
68 CUDA AND DART HAVE THE SAME WHEEL OPENING I GUESS? THANKS
Re: 68 DART [Re: never2ready] #854515
11/15/10 12:07 PM
11/15/10 12:07 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
No, they are different. The Dart has a more flat slab side. Usually a 245/60/15 is about the widest tire for stock or lowered ride rear height 67-69 Darts.
If you jack up the rear, roll fender lips, and move springs in, you can fit more. I don't know exactly on that though.
Re: 68 DART [Re: never2ready] #854516
11/15/10 12:16 PM
11/15/10 12:16 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I ran them on a 8" wheel with a 5.5" back space. The springs were moved in 3/4" with the MP kit and the rear was moved back 1/2". I made a spacer and sandwiched it between the front spring hanger and the chassis mount. The wheel well lip was also trimmed on the outside. The tires had about 1/4" clearence on the inside and outside and about 3/8" to 1/2" on the front.
Re: 68 DART [Re: never2ready] #854517
11/15/10 12:26 PM
11/15/10 12:26 PM
N
N
I WAS GOING TO USE THE OFF SET SPRING HANGERS. I DIDN'T NO IF THAT WOULD HELP OR NOT.
Re: 68 DART [Re: never2ready] #854518
11/15/10 02:42 PM
11/15/10 02:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How come you weren't able to find the caps lock for your log in but you seem to have it well used for your topic and replies ???
Re: 68 DART [Re: JohnRR] #854519
11/15/10 02:46 PM
11/15/10 02:46 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Re: 68 DART [Re: Pntastar69] #854520
11/15/10 04:14 PM
11/15/10 04:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 68 DART [Re: never2ready] #854521
11/15/10 06:08 PM
11/15/10 06:08 PM
Sebring, Florida
Sebring, Florida
I made a new front spring perch and located it next to frame rail, otherwise the tires wouldn't clear the springs. I used the offset shackles on the rear too.
Re: 68 DART [Re: Mopar Grandpa] #854522
11/15/10 06:23 PM
11/15/10 06:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I assume one would have to move the perchs welded to the rear housing ?
Re: 68 DART [Re: JohnRR] #854523
11/15/10 06:52 PM
11/15/10 06:52 PM
Sebring, Florida
Sebring, Florida
Yes, that is correct. However, all my modifications were done prior to locating the perches on the housing as I bought a new housing and the perches were shipped loose.
Re: 68 DART [Re: never2ready] #854524
11/15/10 10:07 PM
11/15/10 10:07 PM
N
N
THANKS FOR YOUR HELP GUYS. AND TO JOHNRR,SORRY IF THE CAP LOCKS BOTHERED YOU. I'LL TRY TO DO BETTER.
Re: 68 DART [Re: never2ready] #854525
11/16/10 08:04 AM
11/16/10 08:04 AM
P
Pntastar69 Offline
Pntastar69  Offline
P
