Re: ALCOHOL VS GAS
[Re: gregsdart]
#817522
09/30/10 10:34 AM
09/30/10 10:34 AM
Posts: 16,931 NC
440Jim
NC
Wayne: Good luck finding E85 around here?? I'll stick with alky. I think the 2.2 ratio is gas carb to alky injection cause there's no way I use that much more with my alky carb. 1.00 gal per 1/8th mile run, 1.5gal per 1/4mile run.
Greg: Methanol is the best of the three for power production. You also use 2.2 times as much of it. For last weekend I put three runs on the car and used about five gallons between the warm up and the runs.
Injectors run very fat at idle, as I'm sure you know. Stoichiometric for alky methanol is 5.5? gas is about 12.5. That works out to 2.27 times more methanol. Your results may vary I believe i was off on how much I used on those three passes. I remember opening a second jug,,,,,,,,,,it was cool up here!
Wade: This past weekend my wife and I both raced our cudas running alcohol - warm up both, two time trials and 4 round each on 20 gallons.
I think we are all talking closer than some may think. Wayne said 1.5 gal/run, Greg said 5/3=1.66 with warm up on a cool day. If he used 1.0 gallon to warm it up at the beginning of the day, then 4/3=1.3gal/run. And I think Wayne's motor is smaller than Gregs too. Some alky carbs with a lean idle can save a little fuel, but it won't run as cool either. Wade had 2 cars x (2 TT + 4 rounds) = 12 passes at 20 gallons equals 1.6 gal/pass including warmup fuel.
I ran methanol for 3 months and kept close track of warm-up and each run and it came out right at 1.5 gal/run plus warm up. This is a 1/4 mile track with a long shut down area and a long drive back to the pits. That all uses fuel.
Re: ALCOHOL VS GAS
[Re: Crizila]
#817524
09/30/10 10:46 AM
09/30/10 10:46 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Just stating the facts - as I and others see them.
When you're not looking for black helicopters and government conspiricies , no doubt. Just playin , Dog. I love the hate. Keep it coming.
Re: ALCOHOL VS GAS
[Re: Challenger 1]
#817525
09/30/10 11:05 AM
09/30/10 11:05 AM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
heres my take on E85 CRIZILLA . i can see you are convinced its not for you and i can respect that as for me in the chicago/nw indiana area E85 is cheap and plentiful ,2.29 a gal. i switched cause i am cheap , i can race more than ever since it is so much more affordable. cooler? i used to come back to the pits and always show 200-220 deg now 180-190 tops. power wise ? i went from 10.20's to 10.0's best so far at norwalk is 9.89 i spent 2 years running 10.20's on gas and switched to E85 and instantly dropped 2 tenths i have switched 5 people over and all but 1 went faster , number 5 was my old man who went 10.98 on gas and 11.01 on E85 . i never tried tuning his car and i know its fat E85 quality? i use the quickfuel tester and yet to see it more than E85-E86 at the 3 stations i go to racing? go to here http://www.proe85.com/they run an 8.90 index and you should see the show the put on tell them guys E85 don't rock carb cost? you can buy a new one for E85 but then can' you sell the old one. i just convert old ones , my first one i got off of ebay and cost me $550 including the kit and paid for itself this season all ready lastly, i changed the oil before norwalk and that was the only one this season and it looked no different than gas. durability? if it breaks it breaks cause they don't last forever but i will venture to say that the fuel type was of minor concern QWKENUF
WAXER
Re: ALCOHOL VS GAS
[Re: QWK_ENUF]
#817528
09/30/10 11:41 AM
09/30/10 11:41 AM
Posts: 7,506 Az
Crizila
Az
as for me
QWKENUF
The cooler running is a big plus for Ethanol, no doubt - and can be a big contributor to improving ET. Carb conversions; if your existing gas carb has interchangeable boosters, yes. Other wise, most gas boosters can't support the addition fuel needed. Durability; You start running CR's in the 14:1 range, durability will be a factor. IMO, wash-down, it's affinity for water, fuel delution, are all durability factors - difficult to measure though. Testing E85 is easy ( and smart ). The question is what do you do with it when you find out it aint 85% ethanol or it has moocho water in it?? As you said, I am convinced it is not the way for me to go right now. Don't mean I won't change my mind tomorrow. I've eatin plenty of crow over the years
Fastest 300
Re: ALCOHOL VS GAS
[Re: B5 Bee]
#817529
09/30/10 12:14 PM
09/30/10 12:14 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
Mike, if you go with E85, you can buy it at Fleetwing, on the east side of Lakeland. It's located about a mile south of E Memorial Blvd(US92) on Combee Rd(CR659).
How much is it a gallon and besides a different carb,any other changes have to be made to run E85?? THANKS!!!!
Re: ALCOHOL VS GAS
[Re: Crizila]
#817531
09/30/10 01:33 PM
09/30/10 01:33 PM
Posts: 4,210 New York
polyspheric
New York
You definitely get more heat energy with ethanol ( about 10% for straight ethanol
The energy content of any alcohol is far less than gasoline. The reason it works is because it will tolerate far richer mixture than gas, and the range of A:F is wider (easier tuning, lower penalty for small jetting errors). The ratios used are never stoichiometric, which only means that all fuel molecules are consumed with no oxygen residue. This number is useless for any performance, and almost useless for normal driving since it's too lean for cold starting and light throttle acceleration, and too rich for best economy. Max power ratios vs. energy content: Gas: 114,000 BTU/gal @ 12.5:1 = 9,120 Methanol: 56,800 BTU/gal @ 5.0:1 = 11,360 Ethanol: 76,100 BTU/gal @ 8.0:1 = 9,513
You get more slightly more power, because you use much more alcohol.
Boffin Emeritus
Re: ALCOHOL VS GAS
[Re: polyspheric]
#817532
09/30/10 02:27 PM
09/30/10 02:27 PM
Posts: 8,165 Left Coast
BobR
Left Coast
And if one uses Q16 or similar oxygenated fuel it becomes a power push.
Re: ALCOHOL VS GAS
[Re: polyspheric]
#817533
09/30/10 02:47 PM
09/30/10 02:47 PM
Posts: 7,506 Az
Crizila
Az
Sorry, I assumed everyone understood that meant at the correct ratio for max power ( which obviously isn't stoic ). Also obviously, aint much that beats gasoline from a BTU standpoint - Why nitrous works so well as a power adder.
Fastest 300
Re: ALCOHOL VS GAS
[Re: Irun5snd8th]
#817535
09/30/10 04:03 PM
09/30/10 04:03 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I run all my stuff on gas and have thought several times about switching to e85 or meth, but have always stayed with gas. The biggest reason is I have it figured out and I can predict my cars very well so I'll probably be staying with gas. All my cooling systems are designed for gas so cooling even in the summer with two classes and late rounds keeps it employed and they stay pretty cool. There are alot of guys around here on alchohol and e85 is coming around as well.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: ALCOHOL VS GAS
[Re: Crizila]
#817537
09/30/10 11:54 PM
09/30/10 11:54 PM
polyspheric
New York
I apologize - I know what you meant, I wasn't correcting you, just clarifying the numbers so that the rich mixture makes sense.
Boffin Emeritus
Re: ALCOHOL VS GAS
[Re: WadeMetzinger]
#817538
09/30/10 11:56 PM
09/30/10 11:56 PM
Posts: 1,015 Down South
DaKuda
Down South
Man you guys pay a lot for alcohol, I've been buying it around here for $2.00 a gallon (55 gallon drums for $105) for the past two years.
This past weekend my wife and I both raced our cudas running alcohol - warm up both, two time trials and 4 round each on 20 gallons. All 1/4 miles passes, so that's like 14 passes. After the last pass we keep the temp up and load them up good and warm (i like them to be 180) so it evaporates all the alcohol out of the oil. I run synthetic oil and don't change it all year, just change and inspect oil filter 2 times a year. We put 200 to 300 passes on the cars each year. So don't believe all the negative stuff you hear from guys that don't run alcohol.
