Clutch Pedal Sticking and Noise
#808216
09/19/10 05:49 PM
09/19/10 05:49 PM
Need a little help. I'll try to describe this the best I can.
Here's the clutch I have: Centerforce 10.95, 18 spline dual friction Disc/PP.
Car sits for a day. When I get in the car, depress the clutch pedal all the way to the floor, and start the car, the pedal does not want to return. In addition, when I get past the 1/3 point in pressing the clutch pedal down, I hear a loud squeeling noise, and the pedal seems stiff.
I tracked the noise back to the clutch fingers (not sure what else to call them). Everything else (linkage, zbar, etc) is lined up, lubed, and moving freely.
Now, when I drive the car and press the clutch in to shift, it returns fine. After driving around town with the car well warmed up, the clutch moves fine, doesn't stick when sitting, and the noise almost goes away.
Thoughts/suggestions?
Thanks!!!
Re: Clutch Pedal Sticking and Noise
[Re: maxie]
#808219
09/19/10 09:13 PM
09/19/10 09:13 PM
when you drop the hammer on it, does the pedal get sucked away from your foot?
I'm fairly certain no, but something I can test just to be sure.
[Re: Pacnorthcuda]
#808220
09/19/10 09:15 PM
09/19/10 09:15 PM
First off--it sounds like a classic case of a diaphram clutch WITH an overcenter spring still installed.....Right? You need to remove the overcenter spring.
I never removed a spring from it, so yes. What's it for? How would I go about removing it? And are there any negative impacts of doing so?
[Re: ]
#808221
09/19/10 09:17 PM
09/19/10 09:17 PM
Posts: 10,232 Someplace you aren't
SomeCarGuy
You need to get it out of there. There are a few methods, everythign from stickign washers in the streched spring to cutting it.
Cutting it is a dangerous deal. Doable but dangerous.
I want my fair share
[Re: ]
#808222
09/19/10 09:19 PM
09/19/10 09:19 PM
Posts: 5,337 the house on the left.
cogen80
its a pain to get out but doable with the car all together,
i thought the centerforce directions said you may have to pull the spring if it does exactly what your describing.
[Re: Pacnorthcuda]
#808224
09/20/10 02:40 PM
09/20/10 02:40 PM
So, removing the center spring will prevent the clutch from sticking to the floor. What about the stiffness and noise? Hard to describe....squeeking, rubbing noise when I depress the clutch. Coming from the clutch fingers. Linkage, zbar, and everything else is moving freely and lined up correctly.
[Re: EV2AAR]
#808226
09/20/10 04:41 PM
09/20/10 04:41 PM
Did you powdercoat the clutch ? J/K
Maybe the squeeking noise is when the kids are underneath the car when I yell "SHIFT"
[Re: DAYCLONA]
#808228
09/20/10 07:59 PM
09/20/10 07:59 PM
Posts: 27,479 So Cal
autoxcuda
So Cal
Get rid of the overcenter spring located over the clutch pedal under the dash, that part of your problem, remove it by sticking a bunch of washer between the coil's, or flat tip screwdrivers, then just push down on the pedal and remove the extended spring by hand, the washers/screwdrivers will keep the spring extended in shape,....see what you have after that regarding pedal/clutch noise/feel
Neat trick!
Mental note taken.
[Re: DAYCLONA]
#808229
09/20/10 10:05 PM
09/20/10 10:05 PM
Sounds like a plan. Thanks for the advice everyone.
