Clutch Pedal Sticking and Noise #808216
09/19/10 05:49 PM
09/19/10 05:49 PM
Anonymous OP
Anonymous OP
Need a little help. I'll try to describe this the best I can.
Here's the clutch I have:
Centerforce 10.95, 18 spline dual friction Disc/PP.
Car sits for a day. When I get in the car, depress the clutch pedal all the way to the floor, and start the car, the pedal does not want to return. In addition, when I get past the 1/3 point in pressing the clutch pedal down, I hear a loud squeeling noise, and the pedal seems stiff.
I tracked the noise back to the clutch fingers (not sure what else to call them). Everything else (linkage, zbar, etc) is lined up, lubed, and moving freely.
Now, when I drive the car and press the clutch in to shift, it returns fine. After driving around town with the car well warmed up, the clutch moves fine, doesn't stick when sitting, and the noise almost goes away.
Thoughts/suggestions?
Thanks!!!
Re: Clutch Pedal Sticking and Noise [Re: ] #808217
09/19/10 06:44 PM
09/19/10 06:44 PM
Indiana
maxie Offline
maxie  Offline
Indiana
when you drop the hammer on it, does the pedal get sucked away from your foot?
Re: Clutch Pedal Sticking and Noise [Re: ] #808218
09/19/10 06:46 PM
09/19/10 06:46 PM
Kirkland, Washington
Pacnorthcuda Offline
First off--it sounds like a classic case of a diaphram clutch WITH an overcenter spring still installed.....Right?
You need to remove the overcenter spring.
Re: Clutch Pedal Sticking and Noise [Re: maxie] #808219
09/19/10 09:13 PM
09/19/10 09:13 PM
Anonymous OP
Anonymous OP
I'm fairly certain no, but something I can test just to be sure.
Re: Clutch Pedal Sticking and Noise [Re: Pacnorthcuda] #808220
09/19/10 09:15 PM
09/19/10 09:15 PM
Anonymous OP
Anonymous OP
I never removed a spring from it, so yes. What's it for? How would I go about removing it? And are there any negative impacts of doing so?
Re: Clutch Pedal Sticking and Noise [Re: ] #808221
09/19/10 09:17 PM
09/19/10 09:17 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You need to get it out of there. There are a few methods, everythign from stickign washers in the streched spring to cutting it.
Cutting it is a dangerous deal. Doable but dangerous.
I want my fair share
Re: Clutch Pedal Sticking and Noise [Re: ] #808222
09/19/10 09:19 PM
09/19/10 09:19 PM
the house on the left.
cogen80 Offline
cogen80  Offline
its a pain to get out but doable with the car all together,
i thought the centerforce directions said you may have to pull the spring if it does exactly what your describing.
Re: Clutch Pedal Sticking and Noise [Re: cogen80] #808223
09/20/10 10:27 AM
09/20/10 10:27 AM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
Yep, you guys are right. I put a center force in my 72 cuda and had the same problem. Can't remember exactly how i got the spring out, but did it myself and don't remember it being a really big deal.
Put a little spring that i got from the hardware store from the clutch pedal to the dash support. Worked great.
Re: Clutch Pedal Sticking and Noise [Re: Pacnorthcuda] #808224
09/20/10 02:40 PM
09/20/10 02:40 PM
Anonymous OP
Anonymous OP
So, removing the center spring will prevent the clutch from sticking to the floor. What about the stiffness and noise? Hard to describe....squeeking, rubbing noise when I depress the clutch. Coming from the clutch fingers. Linkage, zbar, and everything else is moving freely and lined up correctly.
Re: Clutch Pedal Sticking and Noise [Re: ] #808225
09/20/10 03:45 PM
09/20/10 03:45 PM
Northern New Jersey
EV2AAR Offline
EV2AAR  Offline
Northern New Jersey
Did you powdercoat the clutch ? J/K
Re: Clutch Pedal Sticking and Noise [Re: EV2AAR] #808226
09/20/10 04:41 PM
09/20/10 04:41 PM
Anonymous OP
Anonymous OP
Maybe the squeeking noise is when the kids are underneath the car when I yell "SHIFT"
Re: Clutch Pedal Sticking and Noise [Re: ] #808227
09/20/10 07:54 PM
09/20/10 07:54 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Get rid of the overcenter spring located over the clutch pedal under the dash, that part of your problem, remove it by sticking a bunch of washer between the coil's, or flat tip screwdrivers, then just push down on the pedal and remove the extended spring by hand, the washers/screwdrivers will keep the spring extended in shape,....see what you have after that regarding pedal/clutch noise/feel
Re: Clutch Pedal Sticking and Noise [Re: DAYCLONA] #808228
09/20/10 07:59 PM
09/20/10 07:59 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Neat trick!
Mental note taken.
Re: Clutch Pedal Sticking and Noise [Re: DAYCLONA] #808229
09/20/10 10:05 PM
09/20/10 10:05 PM
Anonymous OP
Anonymous OP
Sounds like a plan. Thanks for the advice everyone.
