Oil Dipstick for magnum engine... #779539
08/21/10 12:54 PM
08/21/10 12:54 PM
detroit, mi
POS Dakota Offline OP
detroit, mi
My 408 is almost done and I am having the hardest time finding an aftermarket dipstick.
Is there anything?
I'd like something a little nicer.
I am using the magnum pan too.
Is there anything I can tweak to work?
Lemme know!
For something so stupid I am sure having a hard time finding something.
Re: Oil Dipstick for magnum engine... [Re: POS Dakota] #779540
08/21/10 01:19 PM
08/21/10 01:19 PM
detroit, mi
detroit, mi
Come on!!!
Someone help me with my miniscule stupid problem will ya? hehe
Re: Oil Dipstick for magnum engine... [Re: POS Dakota] #779541
08/23/10 05:44 PM
08/23/10 05:44 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I have the same problem......
I was thinking of using a flexible (wire) dipstick and adapt the leven to my magnum engine..
Re: Oil Dipstick for magnum engine... [Re: Wedgeman] #779542
08/23/10 05:56 PM
08/23/10 05:56 PM
hooziewhatsit Offline
Hmm, I'm going to have the same problem
I tried to pull the stick and tube from a mag engine at the junkyard over the weekend, but that's not going to happen. It was in the block too well
Summit has some cheap ones; I'll probably end up doing that.
Re: Oil Dipstick for magnum engine... [Re: hooziewhatsit] #779543
08/23/10 08:30 PM
08/23/10 08:30 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i recently bought a dipstick tube from the dodge dealer,it was less than $10,mine was for a 3.9 magnum,might be the same as a 318?,if not they will have one for a 318 available,they also have the oem dipstick available,or am i missing something??
Re: Oil Dipstick for magnum engine... [Re: POS Dakota] #779544
08/23/10 08:31 PM
08/23/10 08:31 PM
AndyF Offline
AndyF  Offline
Buy one from your local Dodge dealer.
Re: Oil Dipstick for magnum engine... [Re: AndyF] #779545
08/23/10 08:56 PM
08/23/10 08:56 PM
scratchnfotraction Offline
you did make sure the tube is not broke off in the block..correct?
it will have to be drivin out from the bottom with pan off..I would double check it.
dealer has the stock tube
lokar sells a nice flex one
never had any luck with an after market chrome one,i either broke it going in or it just would not go in
Re: Oil Dipstick for magnum engine... [Re: scratchnfotraction] #779546
08/23/10 11:27 PM
08/23/10 11:27 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
when i had to drive out the broken stub from the bottom i found a drill bit that just fit the hole,turned it around and drove on the sharp end,stub came right out!!
