Oil Dipstick for magnum engine...
#779539
08/21/10 12:54 PM
08/21/10 12:54 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
My 408 is almost done and I am having the hardest time finding an aftermarket dipstick. Is there anything? I'd like something a little nicer. I am using the magnum pan too. Is there anything I can tweak to work? Lemme know! For something so stupid I am sure having a hard time finding something.
Re: Oil Dipstick for magnum engine...
[Re: Wedgeman]
#779542
08/23/10 05:56 PM
08/23/10 05:56 PM
Posts: 3,892 Oregon
hooziewhatsit
Hmm, I'm going to have the same problem I tried to pull the stick and tube from a mag engine at the junkyard over the weekend, but that's not going to happen. It was in the block too well Summit has some cheap ones; I'll probably end up doing that.
[Re: AndyF]
#779545
08/23/10 08:56 PM
08/23/10 08:56 PM
Posts: 15,487 Florida
scratchnfotraction
you did make sure the tube is not broke off in the block..correct? it will have to be drivin out from the bottom with pan off..I would double check it. dealer has the stock tube lokar sells a nice flex one never had any luck with an after market chrome one,i either broke it going in or it just would not go in
