Page 1 of 3 1 2 3
TRANZACT - WHAT A JOKE ! #772376
08/12/10 06:44 PM
08/12/10 06:44 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Well, Ive held my tongue for 3 months...
LONG story - Mods please dont delete this--I dont want someone else have to go through this.
I bought a Tranzact brake back in May. After installing it, the car didnt want to shift to drive, when it did, it would take over 2 seconds then drag the car to a stop.
Went as far as PULLING THE 727 OUT of the car and had it looked at(thanks jim) . Trans is fine,
Its IMPOSSIBLE to get tranzact on the phone and they will not answer my emails. They dont even have any sort of answering machine.
I talked to a guy there when he would answer the phone once every 2 weeks and basically got the run around. Not ONCE did he say "send it back" or " we will make it right" .
Just had me adjust the line pressure (didnt help).
I ended up sticking a Turbo action brake in the car--NO MORE shift problems.Works perfect.
Definatelty the tranzact causing the issues.
So..i just shipped the junk back to them and it was signed for and delivered on august 4th. i included a letter inside because they wont pick up the phone.
Here it is 9 days later and no contact.
Pretty much 3 months of BS.
and probably $400 of my money down the drain
Re: TRANZACT - WHAT A JOKE ! [Re: 493_DART] #772377
08/12/10 06:55 PM
08/12/10 06:55 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
If you purchased with a credit card, can you have them do a charge back?
Re: TRANZACT - WHAT A JOKE ! [Re: mopowers] #772378
08/12/10 07:04 PM
08/12/10 07:04 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
im trying that next. Ive given them plenty of time to simply make this right.
Re: TRANZACT - WHAT A JOKE ! [Re: mopowers] #772379
08/12/10 07:10 PM
08/12/10 07:10 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
It is one guy Joe Chrisman. I just talked to him a couple weeks ago. I no longer run his VB because I was talked into a glide.
Hope you get fixed. But, don't feel bad Rick Allison had me tear up two transmissions and work on his VB a bunch. Only got worse. Burnt up the clutches in one race, which I won. Then made pressure adjustments and the problem got worse. I was told I had bad cases. Some guys have good luck with the A&A. It can be very frustrating. I have ran the Tranzact VB's in several cars with great results. Better than TA by far and the pressure spool valve is secured better in Tranzact's. But, if it aint working going into high sounds like Joe's got some fixing to do. Sorry you didn't get the results I did.
Leon
Re: TRANZACT - WHAT A JOKE ! [Re: Leon441] #772380
08/12/10 08:17 PM
08/12/10 08:17 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Leon
Pretty much sums up my experience....I lost quite a few rounds due to creeping with a T/A brake....I run a glide now.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: TRANZACT - WHAT A JOKE ! [Re: Eric] #772381
08/12/10 08:37 PM
08/12/10 08:37 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I had the opposite happen.
the tranzact creeped a couple inches
the T/A does not creep at all.
Re: TRANZACT - WHAT A JOKE ! [Re: 493_DART] #772382
08/12/10 08:46 PM
08/12/10 08:46 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
No excuse for bad customer service, Keep us posted, I was lookin at their Vb for my torqueflite until now
Re: TRANZACT - WHAT A JOKE ! [Re: 493_DART] #772383
08/12/10 08:46 PM
08/12/10 08:46 PM
iowa
wesw Offline
wesw  Offline
iowa
if it wasn't for bad luck you wouldn't have any at all. your not alone, my luck is total crap also. my motor wasn't as fresh as the guy said it was so i'm doing a complete overhaul on it. made three test passes with it. {it was a total joke}
i put it back in the trailer took it home and pulled the motor back out. i have friend that has a grinner brake if you want me to ck on it for you. wes
598 ci predator
Re: TRANZACT - WHAT A JOKE ! [Re: wesw] #772384
08/12/10 08:52 PM
08/12/10 08:52 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
sorry to hear about the problems but I have to say my Tranzact brake works great and has since day 1 hope you get it straightened out
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: TRANZACT - WHAT A JOKE ! [Re: wesw] #772385
08/12/10 08:53 PM
08/12/10 08:53 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
thanks wes--but i Love my new T/A brake. No creep and works perfect!
Re: TRANZACT - WHAT A JOKE ! [Re: 493_DART] #772386
08/12/10 09:10 PM
08/12/10 09:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been running a T/A brake for YEARS and never had
a creep issue.... mine is the old no low band apply
Re: TRANZACT - WHAT A JOKE ! [Re: MR_P_BODY] #772387
08/12/10 09:47 PM
08/12/10 09:47 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
X2
If you like drag racing, support your local track.
Re: TRANZACT - WHAT A JOKE ! [Re: MR_P_BODY] #772388
08/12/10 09:47 PM
08/12/10 09:47 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I have Installed several T-A brakes over the years. Never had any problems with any of them creeping either. Tranzact? Never bought any from them.
Hope you get your money back. Good luck!
Re: TRANZACT - WHAT A JOKE ! [Re: 727builder] #772389
08/12/10 10:26 PM
08/12/10 10:26 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
first time I have heard anything bad about Tranzact brakes. I have run several, and when I asked pages of replies stating his brakes are the best..My brakes from him...one Pro, and one standard sets at idle, and never creeps.
But hey its impossible for every thing to be perfect, I believe you when you say yours is crap. I also belive you when you say you cant get ahold of him...
Problem is that we know everyone makes mistakes, but how they handle the problem travels a long way...
Hope you get some kind of resolution.
There is some guys on this board who are good friends with him..this might get some results...its a shame it has to come to this though...
Keep us posted..
Re: TRANZACT - WHAT A JOKE ! [Re: Leon441] #772390
08/12/10 10:53 PM
08/12/10 10:53 PM
iowa
rook440 Offline
rook440  Offline
iowa
A&A ,Rick Alison ...hahahahaha ,,,what a joke ..high priced junk !!!
Re: TRANZACT - WHAT A JOKE ! [Re: rook440] #772391
08/12/10 11:01 PM
08/12/10 11:01 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I hope Joe takes care of ya. He's always taken care of me.
Re: TRANZACT - WHAT A JOKE ! [Re: DavidDean] #772392
08/13/10 02:49 AM
08/13/10 02:49 AM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
Re: TRANZACT - WHAT A JOKE ! [Re: 493_DART] #772393
08/13/10 07:27 AM
08/13/10 07:27 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I called Tranzact 4 times last week and Joe answered every time but once.The one time he didnt answer he called back.I got some parts from Joe that was sent out thursday and got them monday.joe will fix the problem.Good luck
Re: TRANZACT - WHAT A JOKE ! [Re: rook440] #772394
08/13/10 08:05 AM
08/13/10 08:05 AM
San Diego
formula S Offline
formula S  Offline
San Diego
I only have had good experiences with Rick. I even called on a saturday and he picked up, and we talked about a trans problem that he had nothing to do with, but took the time to help me out, knowledgeable guy and great customer service.
Re: TRANZACT - WHAT A JOKE ! [Re: formula S] #772395
08/13/10 08:49 AM
08/13/10 08:49 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Same here. I couldn't say enough good things about Rick.
Page 1 of 3 1 2 3
