TRANZACT - WHAT A JOKE !
#772376
08/12/10 06:44 PM
08/12/10 06:44 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Well, Ive held my tongue for 3 months... LONG story - Mods please dont delete this--I dont want someone else have to go through this. I bought a Tranzact brake back in May. After installing it, the car didnt want to shift to drive, when it did, it would take over 2 seconds then drag the car to a stop. Went as far as PULLING THE 727 OUT of the car and had it looked at(thanks jim) . Trans is fine, Its IMPOSSIBLE to get tranzact on the phone and they will not answer my emails. They dont even have any sort of answering machine. I talked to a guy there when he would answer the phone once every 2 weeks and basically got the run around. Not ONCE did he say "send it back" or " we will make it right" . Just had me adjust the line pressure (didnt help). I ended up sticking a Turbo action brake in the car--NO MORE shift problems.Works perfect. Definatelty the tranzact causing the issues. So..i just shipped the junk back to them and it was signed for and delivered on august 4th. i included a letter inside because they wont pick up the phone. Here it is 9 days later and no contact. Pretty much 3 months of BS. and probably $400 of my money down the drain
Re: TRANZACT - WHAT A JOKE !
[Re: mopowers]
#772379
08/12/10 07:10 PM
08/12/10 07:10 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
It is one guy Joe Chrisman. I just talked to him a couple weeks ago. I no longer run his VB because I was talked into a glide.
Hope you get fixed. But, don't feel bad Rick Allison had me tear up two transmissions and work on his VB a bunch. Only got worse. Burnt up the clutches in one race, which I won. Then made pressure adjustments and the problem got worse. I was told I had bad cases. Some guys have good luck with the A&A. It can be very frustrating. I have ran the Tranzact VB's in several cars with great results. Better than TA by far and the pressure spool valve is secured better in Tranzact's. But, if it aint working going into high sounds like Joe's got some fixing to do. Sorry you didn't get the results I did.
Leon
[Re: 493_DART]
#772383
08/12/10 08:46 PM
08/12/10 08:46 PM
Posts: 345 iowa
wesw
iowa
if it wasn't for bad luck you wouldn't have any at all. your not alone, my luck is total crap also. my motor wasn't as fresh as the guy said it was so i'm doing a complete overhaul on it. made three test passes with it. {it was a total joke} i put it back in the trailer took it home and pulled the motor back out. i have friend that has a grinner brake if you want me to ck on it for you. wes
598 ci predator
[Re: wesw]
#772384
08/12/10 08:52 PM
08/12/10 08:52 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
sorry to hear about the problems but I have to say my Tranzact brake works great and has since day 1 hope you get it straightened out
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: wesw]
#772385
08/12/10 08:53 PM
08/12/10 08:53 PM
493_DART
Worst Weather USA
thanks wes--but i Love my new T/A brake. No creep and works perfect!
[Re: 727builder]
#772389
08/12/10 10:26 PM
08/12/10 10:26 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
first time I have heard anything bad about Tranzact brakes. I have run several, and when I asked pages of replies stating his brakes are the best..My brakes from him...one Pro, and one standard sets at idle, and never creeps. But hey its impossible for every thing to be perfect, I believe you when you say yours is crap. I also belive you when you say you cant get ahold of him... Problem is that we know everyone makes mistakes, but how they handle the problem travels a long way... Hope you get some kind of resolution. There is some guys on this board who are good friends with him..this might get some results...its a shame it has to come to this though... Keep us posted..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: rook440]
#772394
08/13/10 08:05 AM
08/13/10 08:05 AM
Posts: 660 San Diego
formula S
San Diego
A&A ,Rick Alison ...hahahahaha ,,,what a joke ..high priced junk !!!
I only have had good experiences with Rick. I even called on a saturday and he picked up, and we talked about a trans problem that he had nothing to do with, but took the time to help me out, knowledgeable guy and great customer service.
[Re: formula S]
#772395
08/13/10 08:49 AM
08/13/10 08:49 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Same here. I couldn't say enough good things about Rick.
