Page 4 of 4 1 2 3 4
Re: My prochargerd 440 [Re: Mr500_wedge] #68470
08/22/09 11:20 AM
08/22/09 11:20 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Tell me about you rear setup..... I had 315/60/15 ET street radials in my chally with no rub issues at all.... was a custom cut dana 60 with dr diffs relo kit and a slightly rolled wheel lip... caltracs stock ride height!
with the standard 55" b body width and 3/4 relo kit still got 28*12.5*15 et street radials in with no issues...
28*12.5*15 ET streets with B Body 55" rear
15*10 5" backspace rim in all the pics!
29.5*10.5*15 MT Slick
315/60/15 ET Street Radial
1/2+ clearance on each side
The slicks and 315's come in at 13 5/8" total width!
Mopar Performance
Re: My prochargerd 440 [Re: Mr500_wedge] #68471
08/22/09 11:21 AM
08/22/09 11:21 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
i adjusted the shocks to max stiffnes, but the rear axle still move so the tires rub the inner fender, :-(
How much room do you have between the tire and the wheel lip opening??Has the wheel lip been modified?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: My prochargerd 440 [Re: moparniac] #68472
08/22/09 11:34 AM
08/22/09 11:34 AM
SWEDEN
Mr500_wedge Offline OP
SWEDEN
i whill get some more photos of the wheel set and post them tomorow.
i have the 11.5 in pro dot hoosier rear wheels with 4.5 in backspacing on the rims.
Thanks for the photos of your SWEET RIDE
Re: My prochargerd 440 [Re: hemi-itis] #68473
08/22/09 11:36 AM
08/22/09 11:36 AM
SWEDEN
SWEDEN
i think i have to center my rear axle wen i get the caltracs.
Re: My prochargerd 440 [Re: hemi-itis] #68474
08/22/09 11:37 AM
08/22/09 11:37 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I had the same problem so i had the diff shortened 1.5 inches per side and the springs moved into frame rail. I also pinched up the inner wheel well lip.
Re: My prochargerd 440 [Re: B1Fish540] #68475
08/22/09 11:42 AM
08/22/09 11:42 AM
SWEDEN
SWEDEN
That is what i am afraid off... thanks for your reply.
or go to the (dot) tyres from my (pro dot) tyres.
Re: My prochargerd 440 [Re: Mr500_wedge] #68476
08/22/09 11:51 AM
08/22/09 11:51 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Ya, my 11.5 Quick Time Pros did the exact same thing, Its too bad because they look great in there! but i drove the car about 10 miles and just about ruined the tires, the sharp edges of the wheel well trim sliced the side wall pretty good. Some guys have good luck using a B-body diff since they are an inch or two narrower and then use offset shackles. Then you can play with the back spacing and fit a tire that size in there.
Re: My prochargerd 440 [Re: Mr500_wedge] #68477
08/22/09 12:05 PM
08/22/09 12:05 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
you should addup the cost of having caltracs and whatever else would go with that kit and what you need for the leafs you have to make things work before you go buying everything.thanks for posting info about your car!
Re: My prochargerd 440 [Re: Mr500_wedge] #68478
05/25/11 11:57 AM
05/25/11 11:57 AM
SWEDEN
SWEDEN
Finally I have driven my car on the 1/4 mile, first time ever , was a really nice experience, not only the driving but also meeting other racers.
I did 4 races, all of them was about the same, no traction, shifted manually from low to high, hit the revlimiter and it didn't shift up unless I let the throttle up a bit, on the way home it popped to my mind that the shift issue was due to the kick down. next time I'll remove the kick down wire, or just run it on Drive. also my stock leaf springs are done, I ordered cal track mono springs, and slicks will be on the car next time (Hoosier pro dot)
Link to one of my runs, time on that run was 11,98 (me at 5:30)
http://www.youtube.com/watch?v=NbFnmUZJPfQ
Re: My prochargerd 440 [Re: Mr500_wedge] #68479
05/25/11 12:02 PM
05/25/11 12:02 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You CANNOT drive a car w/o the throttle pressure linkage..a.k.a. kick-down. YOU WILL smoke the trans. Before you race it again get the correct linkage. Or a Manual valve body.
Coming soon!!!!
Re: My prochargerd 440 [Re: Mr.Yuck] #68480
05/25/11 12:04 PM
05/25/11 12:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
P.S. i'd think you still left a full second or more on the table. My old junk yard 440 w/ 6 psi of uncooled boost went 12.0's at 114.
Re: My prochargerd 440 [Re: Mr.Yuck] #68481
05/25/11 12:10 PM
05/25/11 12:10 PM
SWEDEN
SWEDEN
Thanks for the info , Then I'll leave the kick down alone and run it on D (drive).
Se how much faster it will go next time with slicks and the Cal track monosprings.
Re: My prochargerd 440 [Re: Mr500_wedge] #68482
05/25/11 01:20 PM
05/25/11 01:20 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You should adjust it so it shifts where you want it to. Is it the factory piece? If so the best start is to line up the holes on the mounting bracket w/ a drill bit, then adjust the arm to the carb all the way up until it's almost touching, then adjust the lower arm to the bell crank. You also need a light spring from the bracket to the carb so the arm stays up on the carb linkage. The longer you make the arm/linkage the higher the shift point and quicker the downshifts will be. (I think) What stall and gear are you running? If you haven't upgraded your rear (axles, ring..pinion) I'd try not to load it up to much and come out soft then hammer it.
Re: My prochargerd 440 [Re: Mr.Yuck] #68483
05/25/11 03:09 PM
05/25/11 03:09 PM
SWEDEN
SWEDEN
I have adjusted my kickdown to be fully "open" on full throttle, I have the HEMI kickdown lever in the trans (5,0),
My stall is 3000rpm and gear is 4:10, and I have upgraded axles an pinion, so it should hold together
thanks for the tip
Ps: post photos of your ride if you whant
Re: My prochargerd 440 [Re: Mr500_wedge] #68484
11/12/11 01:43 PM
11/12/11 01:43 PM
SWEDEN
SWEDEN
Re: My prochargerd 440 [Re: Mr500_wedge] #68485
11/12/11 02:40 PM
11/12/11 02:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Cool car, het don't stay in the water to do your burn out. Swipe them roll forward then do your burn out. You did the whole thing in the water and you spun like a MoFo..
Coming soon!!!!
Re: My prochargerd 440 [Re: Mr500_wedge] #68486
11/12/11 02:41 PM
11/12/11 02:41 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
If i was you, i would sell the 8-3/4 and fit a slightly narrower dana, for the bs and to offset the cost of the dana.
I sold my 8-3/4 and it almost paid for the dana i put in and i've got far less weight and power than you have.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Page 4 of 4 1 2 3 4
