Hi all mopar fans.
I promised to make a tread about my new engine buildup, so here it goes
Engine: stroked 440 ( 500) wedge
Procharger: F1
Carburetor: Holley 950cfm stage 2 From PC Performance carburetors
Intake: Victor, Deep port match
Cylinder Heads: Bulldog performance stage 3 ported by Hughes Engines
Rotary: H-beam rods and Eagle crank (Hughes Engines)
Cam: Hughes Engines
Block mods: Half filled with Hard block and Hughes Engines main Stud griddles.
I run it on the Dyno a few weeks ago,
Maybe I Chicken out a little so we only pull it to 6000rpm and 1.1 pounds off Boost, but I didn’t want to risk anything on the dyno, so the number is ok anyway, 774,8 ft 5000rpm and 818Hp 5800rpm and then the valve start to open at 1.1pounds. But it we had to back off the timing a little because it was a bit rough on idle but it was about 840Hp with a little bit more timing. So now I installed a Boost timing master (MSD) so now I can give it more timing
I will post a video from the dyno as soon as my friend is done editing the video.
I want to make a small thanks list too. Thanks to
Hughes Engines, for great Engine parts (Kevin)
The Supercharger Store, for a great Procharger kit (Bob)
Daves, Race shop, for the custom made head gaskets (Dave).
Dyno, Test, for great work tuning the engine (Thomas)
Alucars, For the custom made intercooler and tubes (Fjodde)
And of course members at Moparts for good info and ideas
I try to post a few photos, feel free to post photos off your prochargerd cars too, I am interesting to see different ideas and solutions.
Thanks,
Toni
