Re: My prochargerd 440
[Re: Mr500_wedge]
#68470
08/22/09 11:20 AM
08/22/09 11:20 AM
Posts: 6,295 U.S.
moparniac
U.S.
Tell me about you rear setup..... I had 315/60/15 ET street radials in my chally with no rub issues at all.... was a custom cut dana 60 with dr diffs relo kit and a slightly rolled wheel lip... caltracs stock ride height! ![](/ubbthreads/images/graemlins/thumbs.gif) with the standard 55" b body width and 3/4 relo kit still got 28*12.5*15 et street radials in with no issues... 28*12.5*15 ET streets with B Body 55" rear 15*10 5" backspace rim in all the pics! ![](http://img32.imageshack.us/img32/9257/tirefitment1small.jpg) 29.5*10.5*15 MT Slick ![](http://img245.imageshack.us/img245/4600/tirefitment2small.jpg) 315/60/15 ET Street Radial 1/2+ clearance on each side ![](/ubbthreads/images/graemlins/thumbs.gif) The slicks and 315's come in at 13 5/8" total width! ![](http://img44.imageshack.us/img44/8561/tirefitmentsmall.jpg)
Mopar Performance
[Re: moparniac]
#68472
08/22/09 11:34 AM
08/22/09 11:34 AM
Posts: 91 SWEDEN
Mr500_wedge
SWEDEN
i whill get some more photos of the wheel set and post them tomorow. i have the 11.5 in pro dot hoosier rear wheels with 4.5 in backspacing on the rims. Thanks for the photos of your SWEET RIDE ![](/ubbthreads/images/graemlins/bow.gif)
[Re: Mr500_wedge]
#68476
08/22/09 11:51 AM
08/22/09 11:51 AM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
That is what i am afraid off... thanks for your reply. or go to the (dot) tyres from my (pro dot) tyres.
Ya, my 11.5 Quick Time Pros did the exact same thing, Its too bad because they look great in there! but i drove the car about 10 miles and just about ruined the tires, the sharp edges of the wheel well trim sliced the side wall pretty good. Some guys have good luck using a B-body diff since they are an inch or two narrower and then use offset shackles. Then you can play with the back spacing and fit a tire that size in there.
[Re: Mr500_wedge]
#68477
08/22/09 12:05 PM
08/22/09 12:05 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
i think i have to center my rear axle wen i get the caltracs.
you should addup the cost of having caltracs and whatever else would go with that kit and what you need for the leafs you have to make things work before you go buying everything.thanks for posting info about your car!
[Re: Mr500_wedge]
#68478
05/25/11 11:57 AM
05/25/11 11:57 AM
Posts: 91 SWEDEN
Mr500_wedge
SWEDEN
Finally I have driven my car on the 1/4 mile, first time ever ![](/ubbthreads/images/graemlins/grin.gif) , was a really nice experience, not only the driving but also meeting other racers. I did 4 races, all of them was about the same, no traction, shifted manually from low to high, hit the revlimiter and it didn't shift up unless I let the throttle up a bit, on the way home it popped to my mind that the shift issue was due to the kick down. next time I'll remove the kick down wire, or just run it on Drive. also my stock leaf springs are done, I ordered cal track mono springs, and slicks will be on the car next time (Hoosier pro dot) Link to one of my runs, time on that run was 11,98 (me at 5:30) http://www.youtube.com/watch?v=NbFnmUZJPfQ
[Re: Mr.Yuck]
#68481
05/25/11 12:10 PM
05/25/11 12:10 PM
Posts: 91 SWEDEN
Mr500_wedge
SWEDEN
Thanks for the info ![](/ubbthreads/images/graemlins/bow.gif) , Then I'll leave the kick down alone and run it on D (drive). Se how much faster it will go next time with slicks and the Cal track monosprings.
[Re: Mr500_wedge]
#68482
05/25/11 01:20 PM
05/25/11 01:20 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks for the info , Then I'll leave the kick down alone and run it on D (drive). Se how much faster it will go next time with slicks and the Cal track monosprings.
You should adjust it so it shifts where you want it to. Is it the factory piece? If so the best start is to line up the holes on the mounting bracket w/ a drill bit, then adjust the arm to the carb all the way up until it's almost touching, then adjust the lower arm to the bell crank. You also need a light spring from the bracket to the carb so the arm stays up on the carb linkage. The longer you make the arm/linkage the higher the shift point and quicker the downshifts will be. (I think) What stall and gear are you running? If you haven't upgraded your rear (axles, ring..pinion) I'd try not to load it up to much and come out soft then hammer it.
[Re: Mr.Yuck]
#68483
05/25/11 03:09 PM
05/25/11 03:09 PM
Posts: 91 SWEDEN
Mr500_wedge
SWEDEN
I have adjusted my kickdown to be fully "open" on full throttle, I have the HEMI kickdown lever in the trans (5,0), My stall is 3000rpm and gear is 4:10, and I have upgraded axles an pinion, so it should hold together ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) thanks for the tip ![](/ubbthreads/images/graemlins/thumbs.gif) Ps: post photos of your ride if you whant
[Re: Mr500_wedge]
#68486
11/12/11 02:41 PM
11/12/11 02:41 PM
Posts: 3,210 robin hood country
deaks
robin hood country
If i was you, i would sell the 8-3/4 and fit a slightly narrower dana, for the bs and to offset the cost of the dana. I sold my 8-3/4 and it almost paid for the dana i put in and i've got far less weight and power than you have. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
