70 Cuda brake light switch ?? #668390
04/12/10 07:10 PM
04/12/10 07:10 PM
Fort Workin Tx
Day2Runner Offline OP
Fort Workin Tx
My brake lights quit working and all I can figure out that its the switch on the pedal where can I get a new switch 440 6 727 car ??
thx moparts
Re: 70 Cuda brake light switch ?? [Re: Day2Runner] #668391
04/12/10 07:40 PM
04/12/10 07:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It's real easy to check the switch. Hot on one side and when you push the pedal it's hot on both sides. If it's working then you probably have a bad turn signal switch.
Re: 70 Cuda brake light switch ?? [Re: stumpy] #668392
04/12/10 08:23 PM
04/12/10 08:23 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I just got a new switch a NAPA. Roniie
Re: 70 Cuda brake light switch ?? [Re: stumpy] #668393
04/12/10 08:46 PM
04/12/10 08:46 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Most brake light problems are in the turn signal switch. Try putting your foot on the brake and rock the turn signal switch and see if they magically come back.
Craig
Re: 70 Cuda brake light switch ?? [Re: denfireguy] #668394
04/13/10 12:12 PM
04/13/10 12:12 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
AGREED TURN SIGNAL SWITCH !!!!!!
Re: 70 Cuda brake light switch ?? [Re: dynamite] #668395
04/13/10 11:29 PM
04/13/10 11:29 PM
Fort Workin Tx
Fort Workin Tx
turn signals work fine and with rockin the switch and foot on the brake I still have no brake light
will install new switch
Re: 70 Cuda brake light switch ?? [Re: Day2Runner] #668396
04/14/10 07:54 AM
04/14/10 07:54 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
use a test light on the wiring at the brake light switch, you should have power in when the pedal released and power on both sires depressed.
If no test light use a jumper wire and just cross the 2 wires together and see if you have brake lights.
brake light switches are cheap guess, - turn signal switches , not so cheap
Re: 70 Cuda brake light switch ?? [Re: gtx6970] #668397
04/14/10 11:19 AM
04/14/10 11:19 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
BTW just because the trun signals and flashers work doesn't mean the turn signal switch is good. The brake ligts are a seperate circuit in the switch.
Re: 70 Cuda brake light switch ?? [Re: Day2Runner] #668398
04/14/10 03:23 PM
04/14/10 03:23 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
EZ to check..
Jumper the 2 wires on the brake lite switch..
1. If the lites works, the switch is bad
2. If the lites don't work, check elsewhere
Just my $0.01..
