Re: 70 Cuda brake light switch ??
[Re: stumpy]
#668393
04/12/10 08:46 PM
04/12/10 08:46 PM
Posts: 1,822 Colorado
denfireguy
Colorado
It's real easy to check the switch. Hot on one side and when you push the pedal it's hot on both sides. If it's working then you probably have a bad turn signal switch.
Most brake light problems are in the turn signal switch. Try putting your foot on the brake and rock the turn signal switch and see if they magically come back. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Day2Runner]
#668398
04/14/10 03:23 PM
04/14/10 03:23 PM
Posts: 5,447 So Cal
Sinitro
So Cal
EZ to check.. Jumper the 2 wires on the brake lite switch.. 1. If the lites works, the switch is bad 2. If the lites don't work, check elsewhere Just my $0.01.. ![](/ubbthreads/images/graemlins/wink.gif)
