Zeeker Heads??? #647297
03/21/10 08:25 PM
03/21/10 08:25 PM
Cumberland, MD
Supersonic Offline OP
Cumberland, MD
I am thinking about buying a set of the zeeker heads, do these heads have any problems? I've heard they flow like the indy-1s. Do they use stock style valve covers, rocker arm assembly ect?
Re: Zeeker Heads??? [Re: Supersonic] #647298
03/21/10 08:28 PM
03/21/10 08:28 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
they are the original -1 heads.....
Re: Zeeker Heads??? [Re: joshking440] #647299
03/21/10 09:42 PM
03/21/10 09:42 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
They were prone to cracking depending on what casting run they were from. They were one of the first aluminum wedge heads out there
Re: Zeeker Heads??? [Re: Supersonic] #647300
03/21/10 10:06 PM
03/21/10 10:06 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
They were originally designed by Loren Zedek back around 1989. They were the first aluminum version of the Max Wedge that I can remember. Some of the castings had porosity problems. Never heard of the cracking problem before this post. They use off set intake rockers (same as the 440-1) and rocker shafts are in the stock location, so valve covers are readily available. They are a lot taller than a stock head and the set I have uses the longest available Chevy valves with 11/32 stems. Mine has a lot of metal around the ports and could be opened up larger than a max wedge port if you really needed to do that. They do oil thru the head like a stock 440 head does.
Old Geezer Racing
Re: Zeeker Heads??? [Re: SCATPACK 1] #647301
03/22/10 05:27 AM
03/22/10 05:27 AM
Cumberland, MD
Cumberland, MD
Do they have a raised exhaust port?
Re: Zeeker Heads??? [Re: Supersonic] #647302
03/22/10 11:16 AM
03/22/10 11:16 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Also on the Zeeker heads,you need to plug the 1/4" oil hole and drill it back out to about .060-.080. If not it will fill you valve covers full of oil @ about the 1/8 mile mark. Todd Marsh done a set for us 2-3 years ago he may can help you out with them.
The Zeekers I had were the raised exhaust ports same as the Indy 440-1 heads.
The cracking the Zeeker heads(on most anyway) were from being ported. The thickness(all the same thickness) of the casting were not the best on them. But most head porters knew this and did not push it to the limit on opening them up.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Zeeker Heads??? [Re: MRMOPAR622] #647303
03/22/10 02:52 PM
03/22/10 02:52 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
The int and exh ports are in the same location as the Indy -1.
I had a set that made some really great power.
No porosity issues with min that people always mention.
Mine were fully ported, used and Indy Dominator intake and 5/16 valves.
Mine oiled through the block like stock heads but they were tapped and a pill inserted to restrict the amount of oil going to the heads, they didn't oil like the -1 with the external oil lines.
Standard Pistons, standard valvcovers, etc.
They use the same rockers, actually the part number for Harland Sharp has a -z in it because they were designed for the zeeker but they also work on the -1s.
I wanted to slow my car down so I traded them for a set of Indy -1s that were not ported.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
