2 speed to 3 speed wiper motor swap HELP!!! #646050
03/20/10 01:15 PM
03/20/10 01:15 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Hello again all , once again I have another problem though this time electrical. On our resto build we decided to put in a shaker scoop instead of what it came with. We found that it wouldn't fit with the 2 speed wiper motor the car came with, so we bought a 3 speed motor at a swap meet and restored it. Upon installation, we found that the swap wasn't so easy...
The wiring is or course for a 2 speed, along with the switch, so there are going to be obvious problems but I didn't think they were going to be too bad. We have no park, and cannot seem to figure out the high and low speed settings and the ground is in and out depending on how we wire it. Strange... Is it possible for me to take a 3 speed switch, pop in the plug and pop the switch into the dash?? If not, what are my options????
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: 2 speed to 3 speed wiper motor swap HELP!!! [Re: knyech1] #646051
03/20/10 02:26 PM
03/20/10 02:26 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
something to remember is the linkages under the cowl are different between 2 and 3 speed
I know the switch is different and only assume the wiring is as well, but the wiring harness may already have the proper wires in the harness
otherwise Jules should be along with confirmation soon
Re: 2 speed to 3 speed wiper motor swap HELP!!! [Re: gtx6970] #646052
03/20/10 02:35 PM
03/20/10 02:35 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
We have installed the proper linkage. Sorry forgot to mention that.
Re: 2 speed to 3 speed wiper motor swap HELP!!! [Re: knyech1] #646053
03/20/10 02:38 PM
03/20/10 02:38 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
And if a switch is all I need, where would I find one? I have not looked for one before.
Re: 2 speed to 3 speed wiper motor swap HELP!!! [Re: knyech1] #646054
03/20/10 03:03 PM
03/20/10 03:03 PM
N
NITROUSN Offline
NITROUSN  Offline
N
This is what I found and have posted before.
Here is a update. I looked in my 69 parts manual and this is what i found.
1-The dash wiring is the same all engines all wiper systems. This is for 69-b-body models.
2- Wiper motor 2 speed-2770090
3 speed 2983116
3-wiper link 2 speed 2631799
3 speed 2822273
4-Bushing 2 speed 2631766
3 speed 2580200
5-Switch 2 speed 3004177
3 speed 2864014
The rest of the linkage ect is all the same.
Re: 2 speed to 3 speed wiper motor swap HELP!!! [Re: NITROUSN] #646055
03/20/10 03:35 PM
03/20/10 03:35 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
So I am guessing all I need is a 3 speed switch and I will be ok??
Re: 2 speed to 3 speed wiper motor swap HELP!!! [Re: knyech1] #646056
03/20/10 04:05 PM
03/20/10 04:05 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
E body 2-3 swap, I assume with the mention of a SHAKER, it's an E body? ....3 speed motor, harness is attached, plug into main bulkhead, you have this plus the correct linkage under the cowl, now you need the 3 speed switch and your done
Check to confirm your switch connector looks like this
If you have problems locating a 3 speed E body switch, I have a "few"...PM me on Moparts
Mike
Re: 2 speed to 3 speed wiper motor swap HELP!!! [Re: DAYCLONA] #646057
03/20/10 04:35 PM
03/20/10 04:35 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Hmmm yeah ours doesn't look like that... I might be PM-ing you for a switch or other questions here soon...
Re: 2 speed to 3 speed wiper motor swap HELP!!! [Re: knyech1] #646058
03/20/10 05:36 PM
03/20/10 05:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Maybe.. what car are you working on?
Re: 2 speed to 3 speed wiper motor swap HELP!!! [Re: NITROUSN] #646059
03/20/10 11:53 PM
03/20/10 11:53 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Dayclona that is a 72-74 3 speed switch.
A 70-71 variable speed switch has 2 plugs. Like pictured.
You will need a variable speed switch ending with part number 380.
The linkage should have a half inch brass bushing at the wiper crank arm connection.
Part number ending in 293.
The crank arm must be a 289 ending part number.
Next the motor you bought must have the large half inch size nut on the rear shaft. If it is the
3/8 size nut , you have purchased a late 71- 74 style and may cause issues.
Jules
Re: 2 speed to 3 speed wiper motor swap HELP!!! [Re: JulesdaWiperman] #646060
03/21/10 12:03 AM
03/21/10 12:03 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your correct Jules,....the OP still hasn't stated what year E body, or what parts are in play yet,...but IIRC using a wiring diagram, and slicing off one of the molded "speed" connectors use can still use a 72-4 switch on the 70-1 harness, as I recall doing that on my 71 Challenger some time ago (like 30 yrs ago )
Re: 2 speed to 3 speed wiper motor swap HELP!!! [Re: DAYCLONA] #646061
03/21/10 10:58 PM
03/21/10 10:58 PM
Hilliard, Ohio
GKMOPAR Offline
GKMOPAR  Offline
Hilliard, Ohio
Is there is one terminal that is not used on the 3 speed switch on 70-71 e bodies?
