2 speed to 3 speed wiper motor swap HELP!!!
#646050
03/20/10 01:15 PM
03/20/10 01:15 PM
Posts: 486 IL
knyech1
IL
Hello again all , once again I have another problem though this time electrical. On our resto build we decided to put in a shaker scoop instead of what it came with. We found that it wouldn't fit with the 2 speed wiper motor the car came with, so we bought a 3 speed motor at a swap meet and restored it. Upon installation, we found that the swap wasn't so easy... The wiring is or course for a 2 speed, along with the switch, so there are going to be obvious problems but I didn't think they were going to be too bad. We have no park, and cannot seem to figure out the high and low speed settings and the ground is in and out depending on how we wire it. Strange... Is it possible for me to take a 3 speed switch, pop in the plug and pop the switch into the dash?? If not, what are my options????
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: 2 speed to 3 speed wiper motor swap HELP!!!
[Re: knyech1]
#646053
03/20/10 02:38 PM
03/20/10 02:38 PM
Posts: 486 IL
knyech1
IL
And if a switch is all I need, where would I find one? I have not looked for one before.
knyech1-
[Re: NITROUSN]
#646055
03/20/10 03:35 PM
03/20/10 03:35 PM
Posts: 486 IL
knyech1
IL
So I am guessing all I need is a 3 speed switch and I will be ok??
knyech1-
[Re: DAYCLONA]
#646057
03/20/10 04:35 PM
03/20/10 04:35 PM
Posts: 486 IL
knyech1
IL
Hmmm yeah ours doesn't look like that... I might be PM-ing you for a switch or other questions here soon...
knyech1-
