69-383 Motor not making enough low end torque #624394
02/25/10 09:24 PM
02/25/10 09:24 PM
TX
68 Dart GTS Offline OP
TX
Mopart guys, i'm having very low end torque problems. I have a 68 dart 383. It is pretty much stock but bored 30 over, schumacher headers, 383 torker mainifold with a new holley 770 avenger carb, new Comp. XE274 cam and lifters, stock heads ported and polished with HD springs, new pushrods, rebuilt 727 trans, 323 sure grip and 3000 hughes stall converter, stock elct. ignition with orange ECU box. Everything is pretty much new in the motor, compression test is good, vac.is good but it's totally a dog on the low end out of the hole. the motor runs great and it seems to make good power but it just seems like its not getting the power to the rear wheels at launch. I'm starting to think the new in the box stall converter which i bought from a friend may be clogged or have trash in it. Any suggestions are similar problems and fixes would greatly be appreciated. I have gotten pretty frustrated and don't want to just keep throwing more money at it and hope the problem gets solved. Compression is approx 9.5 - 1 to 10-1,vac.@ 14, intl., dist. @ 12. Thanks.
Re: 69-383 Motor not making enough low end torque [Re: 68 Dart GTS] #624395
02/25/10 10:45 PM
02/25/10 10:45 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
you dont have anywhere near enough initial advance! i,d try 25 deg initial and see if it picks it up... good luck dan
Re: 69-383 Motor not making enough low end torque [Re: 68 Dart GTS] #624396
02/25/10 10:57 PM
02/25/10 10:57 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
What does the converter flash to? That 274 cam is what, 230/236 at .050? I would think 3500-3800 stall would be about right for that cam. You might consider switching to a Performer RPM or DP4B too, that Torker isn't doing you any favors in the low end department. As mentioned already. more initial timing wouldn't hurt.
Re: 69-383 Motor not making enough low end torque [Re: forphorty] #624397
02/25/10 11:01 PM
02/25/10 11:01 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
The torker intake isn't your freind. Would be ok with 4;10 or 4;30 gears and a 4 speed. My 440 likes 22 degree's initial timing.
Re: 69-383 Motor not making enough low end torque [Re: Dougsmopars] #624398
02/25/10 11:23 PM
02/25/10 11:23 PM
TX
TX
Thanks keep the suggestions coming. I have already thought about switching the torker intake and have a old Weiland intake simalar to the eddl.RPM that i'm gong to switch out this weekend to see what kind of improvements it will make along with messing with the timing again, which we have adjusted quite a bit already.
Re: 69-383 Motor not making enough low end torque [Re: 68 Dart GTS] #624399
02/26/10 01:27 AM
02/26/10 01:27 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You are going to need to recurve your distributor. No way around that one. I would try first setting it up for 18 initial, 38 total. Then if the motor likes it and doesn't fight back when trying to restart the motor when hot, keep tweaking the initial up as high as you can, but recurve to keep the total at 38. And you'll want all your advance in around the 2500rpm range.
I do agree with the other replies, that cam is a bit big for a 383 with 3.23 gears and a 3000rpm converter.
Re: 69-383 Motor not making enough low end torque [Re: 68 Dart GTS] #624400
02/26/10 04:46 AM
02/26/10 04:46 AM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
I would try more advance first, as much as you can get without it rattling when you lay into it- probably near 30* base, 36-38* max with 9.5 comp and open chamber heads, if thats not enough get a tight 8" converter or a 4 speed.
Re: 69-383 Motor not making enough low end torque [Re: DaytonaTurbo] #624401
02/26/10 08:59 AM
02/26/10 08:59 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
is that verified or what the pistons are supposed to give?
KB flat tops at 0 deck, steel shim head gasket, and OEM 906 heads (~92cc) usually only yields 8.5-8.7:1. with the 6cc dome, its in the 9.4-9.6:1 range....but their specs, you need to mill the deck ~.024" to get them at 0 deck...drop them into an uncut block, drop those compression figures another .2 points. if they are stock type replacement pistons in the hole, you're probably in the upper 7's to low 8's for compression at best, unless you've milled the snot out of the heads or the block deck.
what's your cranking compression in PSI?
initial with that cam, assuming actual compression is in the 8's, I'd run about 18-20. if your cranking compression comes in low (under 150), I'd seriously consider dropping in cam size a bit (lunati voodoo 60302 is what I'd pick), or opening up the motor and advancing installed centerline of the cam 4-6 degrees to close the intake valve sooner to gain cranking compression. the torker is also a mediocre intake...especially if you're looking for "street" performance...
http://hotrod.automotive.com/62106/hrdp-0712-mopar-intake-manifold-comparo/edelbrock-383.html
check out the torque figures at 3000 RPM...it's down 25 lb-ft from a weiand action plus, or eddie performer, and most likely a stock intake.
2017 Grand Cherokee Overland
Re: 69-383 Motor not making enough low end torque [Re: 68 Dart GTS] #624402
02/26/10 09:23 AM
02/26/10 09:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you'll never get good low-end grunt w/ 3.23 gears.
Coming soon!!!!
Re: 69-383 Motor not making enough low end torque [Re: Mr.Yuck] #624403
02/26/10 02:56 PM
02/26/10 02:56 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
ding-ding. Much more fun with good gears.(4.56)
Re: 69-383 Motor not making enough low end torque [Re: RemCharger] #624404
02/26/10 03:08 PM
02/26/10 03:08 PM
Detroit, Michigan, USA!
peelerboy Offline
peelerboy  Offline
I'm with the guys on the gear. You'll get your maximum bang-for-the-buck by installing at least 3.91's, if not something steeper.
At the very least, get your distributor recurved to allow full advance at a lower rpm. (e.g. 2k) This will bring a lot more low end grunt into play.
Dale
Re: 69-383 Motor not making enough low end torque [Re: peelerboy] #624405
02/26/10 03:46 PM
02/26/10 03:46 PM
michigan woods
imfixinmopars426 Offline
michigan woods
remember..a 69 runner came with 3.23's..small carb..a low dual plane intake,and a 214-220@.050 cam..and ran strong. you have..too much cam,too big intake..maybe too low comp= no torque. a dog w/ 3k stall,which w/ no torgue= low flash i bet.2-2200?..and 3.23 makes a pig out of it...oh and set the total at 36deg FIRST! i would look into a 214-224 cam,a performer/perf rpm? intake and tune it right and have a strong driver! classic mis-match issue.
Re: 69-383 Motor not making enough low end torque [Re: peelerboy] #624406
02/26/10 03:54 PM
02/26/10 03:54 PM
Downey, IA
Gt383 Offline
Gt383  Offline
Downey, IA
That short stroke motor is crying for big gear...That 3.23 is a highway gear for that short stroke, I'd want at least a 4.30 or better to maximize ur combo, u wont believe hat it'll do to that car.
If I hafta come in and getchya.......I'm gonna getchya!
Re: 69-383 Motor not making enough low end torque [Re: 68 Dart GTS] #624407
02/26/10 06:29 PM
02/26/10 06:29 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
What is your cylinder pressure?
Re: 69-383 Motor not making enough low end torque [Re: DaytonaTurbo] #624408
03/01/10 09:58 PM
03/01/10 09:58 PM
TX
TX
Thnaks guys, i know i have a mis-matched set up, i was trying to work from a budget and alot of horse trading to build this car/engine and am paying for it now. The compression check is at 160-165 @ all cylinders, and i went with the recommendation of comp. cams on using the XE274 230-488 cam with the current set up, but they said using higher gears would be better... i debated on using the XE268 cam which is 224-477 but comp. recommended the 274 with the stall speed etc. I'm working on putting the Weiland intake on and going with a higher gear probably 3.55 to 3.90. this is going to be my weekend cruiser and i really want to be able to run 70 mph without all the RPMS. Thanks again to all for your help and imput. Also the Int. timing is at 25-28 which i stated a incorrct int. timing in my original post.
Re: 69-383 Motor not making enough low end torque [Re: 68 Dart GTS] #624409
03/01/10 10:27 PM
03/01/10 10:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Lots of good advise here. I can tell you that I ran a very mild 383 for a few years. I used the same orange ECU with a stock dist I recurved and in fact that same dist is in the 400 in my sons Dart right now. I installed the MR Gasket spring kit and set the total at 38 all in by 2000 rpm. I let the initial timing fall where it did as long as it had full timing by 38 I was happy. The initial was around 18 to 22 when I actually looked at it. It had a stock bottom end including stock pistons. The 452 heads had some mild pocket porting and were cut for 9.5 comp. I had the MP .484 cam in it and used the Eddy RPM intake. Had a 3000 tight TA converter and 3.91's all in a 72 Dart. It had great bottom end as it would fry the street tires even if you nailed it from a 10 to 15 mph roll and it ran as fast as 12.30's @ 110 at the track.
I would take some of the advise these guys have given you and get the initial timing up more and definetly 3.91 gears will help. Good luck , Ron
Re: 69-383 Motor not making enough low end torque [Re: 68 Dart GTS] #624410
03/02/10 10:06 AM
03/02/10 10:06 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
one thing I think a lot of mopar guys do is overcam...I woulda listened to the little voice in your head and run the XE268...that said, if you want to keep your 3.23's, I'd definitely run the dual plane intake, and I'd actually pop the front of the motor apart and degree the cam in to a 102* ICL from comp's recommended 106.
Re: 69-383 Motor not making enough low end torque [Re: 383man] #624411
03/02/10 10:41 AM
03/02/10 10:41 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I'd try that set up with the 3.23's. I think you'll be happy.
Re: 69-383 Motor not making enough low end torque [Re: patrick] #624412
03/02/10 04:49 PM
03/02/10 04:49 PM
michigan woods
michigan woods
[quote
exactly! decide what gear to run for YOUR usage,and build the engine for that...dont put 3.91-4.10's and be afraid to drive the car like you REALLT WANT TO!
Re: 69-383 Motor not making enough low end torque [Re: imfixinmopars426] #624413
03/02/10 06:04 PM
03/02/10 06:04 PM
IL
furious70 Offline
furious70  Offline
IL
unless I missed it in here somewhere, you didn't say and no one asked if you degreed the cam when you put it together? If not, that's an obv. first thing.
With a 3.23 gear you may like the Weiand intake better, but if you are going to move to a 3.55 or 3.91 I would personally leave that torker on there.
Too late now, but I know several guys who love the XE268 in their 383's.
70 Sport Fury
68 Charger
69 Coronet
72 RR
