69-383 Motor not making enough low end torque
#624394
02/25/10 09:24 PM
02/25/10 09:24 PM
Posts: 25 TX
68 Dart GTS
TX
Mopart guys, i'm having very low end torque problems. I have a 68 dart 383. It is pretty much stock but bored 30 over, schumacher headers, 383 torker mainifold with a new holley 770 avenger carb, new Comp. XE274 cam and lifters, stock heads ported and polished with HD springs, new pushrods, rebuilt 727 trans, 323 sure grip and 3000 hughes stall converter, stock elct. ignition with orange ECU box. Everything is pretty much new in the motor, compression test is good, vac.is good but it's totally a dog on the low end out of the hole. the motor runs great and it seems to make good power but it just seems like its not getting the power to the rear wheels at launch. I'm starting to think the new in the box stall converter which i bought from a friend may be clogged or have trash in it. Any suggestions are similar problems and fixes would greatly be appreciated. I have gotten pretty frustrated and don't want to just keep throwing more money at it and hope the problem gets solved. Compression is approx 9.5 - 1 to 10-1,vac.@ 14, intl., dist. @ 12. Thanks.
Re: 69-383 Motor not making enough low end torque
[Re: 68 Dart GTS]
#624399
02/26/10 01:27 AM
02/26/10 01:27 AM
DaytonaTurbo
Manitoba, Canada
along with messing with the timing again, which we have adjusted quite a bit already.
You are going to need to recurve your distributor. No way around that one. I would try first setting it up for 18 initial, 38 total. Then if the motor likes it and doesn't fight back when trying to restart the motor when hot, keep tweaking the initial up as high as you can, but recurve to keep the total at 38. And you'll want all your advance in around the 2500rpm range.
I do agree with the other replies, that cam is a bit big for a 383 with 3.23 gears and a 3000rpm converter.
[Re: DaytonaTurbo]
#624401
02/26/10 08:59 AM
02/26/10 08:59 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
is that verified or what the pistons are supposed to give? KB flat tops at 0 deck, steel shim head gasket, and OEM 906 heads (~92cc) usually only yields 8.5-8.7:1. with the 6cc dome, its in the 9.4-9.6:1 range....but their specs, you need to mill the deck ~.024" to get them at 0 deck...drop them into an uncut block, drop those compression figures another .2 points. if they are stock type replacement pistons in the hole, you're probably in the upper 7's to low 8's for compression at best, unless you've milled the snot out of the heads or the block deck. what's your cranking compression in PSI? initial with that cam, assuming actual compression is in the 8's, I'd run about 18-20. if your cranking compression comes in low (under 150), I'd seriously consider dropping in cam size a bit (lunati voodoo 60302 is what I'd pick), or opening up the motor and advancing installed centerline of the cam 4-6 degrees to close the intake valve sooner to gain cranking compression. the torker is also a mediocre intake...especially if you're looking for "street" performance... http://hotrod.automotive.com/62106/hrdp-0712-mopar-intake-manifold-comparo/edelbrock-383.htmlcheck out the torque figures at 3000 RPM...it's down 25 lb-ft from a weiand action plus, or eddie performer, and most likely a stock intake.
[Re: Mr.Yuck]
#624403
02/26/10 02:56 PM
02/26/10 02:56 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
you'll never get good low-end grunt w/ 3.23 gears.
ding-ding. Much more fun with good gears.(4.56)
[Re: peelerboy]
#624405
02/26/10 03:46 PM
02/26/10 03:46 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
remember..a 69 runner came with 3.23's..small carb..a low dual plane intake,and a 214-220@.050 cam..and ran strong. you have..too much cam,too big intake..maybe too low comp= no torque. a dog w/ 3k stall,which w/ no torgue= low flash i bet.2-2200?..and 3.23 makes a pig out of it...oh and set the total at 36deg FIRST! i would look into a 214-224 cam,a performer/perf rpm? intake and tune it right and have a strong driver! classic mis-match issue.
[Re: 68 Dart GTS]
#624407
02/26/10 06:29 PM
02/26/10 06:29 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
What is your cylinder pressure?
[Re: 68 Dart GTS]
#624410
03/02/10 10:06 AM
03/02/10 10:06 AM
patrick
Grand Haven, MI
Thnaks guys, i know i have a mis-matched set up, i was trying to work from a budget and alot of horse trading to build this car/engine and am paying for it now. The compression check is at 160-165 @ all cylinders, and i went with the recommendation of comp. cams on using the XE274 230-488 cam with the current set up, but they said using higher gears would be better... i debated on using the XE268 cam which is 224-477 but comp. recommended the 274 with the stall speed etc. I'm working on putting the Weiland intake on and going with a higher gear probably 3.55 to 3.90. this is going to be my weekend cruiser and i really want to be able to run 70 mph without all the RPMS. Thanks again to all for your help and imput. Also the Int. timing is at 25-28 which i stated a incorrct int. timing in my original post.
one thing I think a lot of mopar guys do is overcam...I woulda listened to the little voice in your head and run the XE268...that said, if you want to keep your 3.23's, I'd definitely run the dual plane intake, and I'd actually pop the front of the motor apart and degree the cam in to a 102* ICL from comp's recommended 106.
[Re: imfixinmopars426]
#624413
03/02/10 06:04 PM
03/02/10 06:04 PM
Posts: 2,255 IL
furious70
IL
unless I missed it in here somewhere, you didn't say and no one asked if you degreed the cam when you put it together? If not, that's an obv. first thing.
With a 3.23 gear you may like the Weiand intake better, but if you are going to move to a 3.55 or 3.91 I would personally leave that torker on there.
Too late now, but I know several guys who love the XE268 in their 383's.
70 Sport Fury 68 Charger 69 Coronet 72 RR
