What build would make the most RELIABLE 1000hp SB?
#579321
01/11/10 12:01 AM
01/11/10 12:01 AM
Posts: 22,697 Bitopia
jcc
Bitopia
Say cost is no object, what would be a 1000HP build that would give the most RELIABLE SB motor, w/EFI, no NOS, streetable, non drag, Pump gas or E-85, ease to sort out, and lighter being better. Reliable being the most important criteria.
Post deleted by Defbob
[Re: jcc]
#579324
01/11/10 12:08 AM
01/11/10 12:08 AM
Re: What build would make the most RELIABLE 1000hp SB?
[Re: Dos Snails]
#579326
01/11/10 02:02 AM
01/11/10 02:02 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: jcc]
#579328
01/11/10 06:50 AM
01/11/10 06:50 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Number 1 thing would be a after market block with siamese cylinders, nice alum heads, forged or billet crank, H-beam rods, roller cam, EFI then your choice of turbo/turbos.... JMO
[Re: MR_P_BODY]
#579329
01/11/10 09:56 AM
01/11/10 09:56 AM
jcc
Bitopia
Now that's what I looking for, current build is already a Tall Alum 360 Alum mopar Block, which forces a dry sump, W-8 ported heads, then what are the most reliable endurance valves for turbo builds, max bore up to 4.180", need to decide stroke/cubes (low end is not critical, throttle response is more so), forged crank or is billet better/needed choice, I would rather limit rpms to keep reliability, rod size 2.1,2.0,1.88?, Ti rods are a consideration, roller is a definite, turbo is of course most obvious choice, but single vs dual turbos, intercooler just makes sense, but thought just maybe a Procharger type set-up might be more reliable to set-up and maintain for someone like me that knows just enough to get in trouble. As tough as it might be to finally put this package together, I am not in a position to be able to afford scattering it, hence reliability is of key importatnce in the chase for 1000 hp.
[Re: jcc]
#579331
01/11/10 10:10 AM
01/11/10 10:10 AM
MR_P_BODY
I wouldnt go the Procharger route it uses HP to make HP where the turbo is basically free... valves... a good stainless valve is plenty... no need for a Ti rod... your not spinning it hard.... a chevy rod size is fine. It sounds like you would need to get the turbo setup tuned for you but there are plenty of shops that can put it on a dyno and take care of that for you
[Re: MR_P_BODY]
#579332
01/11/10 10:26 AM
01/11/10 10:26 AM
Posts: 3,695 nc
emarine01
nc
Free....
[Re: emarine01]
#579333
01/11/10 10:29 AM
01/11/10 10:29 AM
MR_P_BODY
Free....
Notice that word "basically"
[Re: emarine01]
#579335
01/11/10 10:45 AM
01/11/10 10:45 AM
MR_P_BODY
Got ya , Hey I was only thinkin
LOL... thinkin a good thing
[Re: MR_P_BODY]
#579337
01/11/10 11:13 AM
01/11/10 11:13 AM
[Re: jcc]
#579339
01/12/10 10:19 AM
01/12/10 10:19 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Buy a clean, used W8 or P5 comp eliminator motor and put a longer arm in it.
8.30's @3400 lbs
