What build would make the most RELIABLE 1000hp SB? #579321
01/11/10 12:01 AM
01/11/10 12:01 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Say cost is no object, what would be a 1000HP build that would give the most RELIABLE SB motor, w/EFI, no NOS, streetable, non drag, Pump gas or E-85, ease to sort out, and lighter being better. Reliable being the most important criteria.
Re: What build would make the most RELIABLE 1000hp SB? [Re: jcc] #579322
01/11/10 12:07 AM
01/11/10 12:07 AM
R5 P7 with a turbo, intercooled and EFI with E85
Re: What build would make the most RELIABLE 1000hp SB? [Re: jcc] #579323
01/11/10 12:08 AM
01/11/10 12:08 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Give either Scott Koffel or RyanJ a call Shadydell.. Actually, get ahold of MLaboda. He has a very nice Ray Barton Pro Stock truck engine for sale. All fresh from RyanJ. Should be near that 1k.. Very nice engine.
Details:
http://www.yellowbullet.com/forum/showthread.php?p=3420666#post3420666
Post deleted by Defbob [Re: jcc] #579324
01/11/10 12:08 AM
01/11/10 12:08 AM
Re: What build would make the most RELIABLE 1000hp SB? #579325
01/11/10 12:44 AM
01/11/10 12:44 AM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
you already know the answer, Turbo!
Re: What build would make the most RELIABLE 1000hp SB? [Re: Dos Snails] #579326
01/11/10 02:02 AM
01/11/10 02:02 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Turbo, and or Turbo/s!!!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: What build would make the most RELIABLE 1000hp SB? [Re: topfueldart] #579327
01/11/10 02:36 AM
01/11/10 02:36 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Just in case anybody didn't already mention it, I'd say go turbos...
Re: What build would make the most RELIABLE 1000hp SB? [Re: jcc] #579328
01/11/10 06:50 AM
01/11/10 06:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Number 1 thing would be a after market block with
siamese cylinders, nice alum heads, forged or billet
crank, H-beam rods, roller cam, EFI then your choice
of turbo/turbos.... JMO
Re: What build would make the most RELIABLE 1000hp SB? [Re: MR_P_BODY] #579329
01/11/10 09:56 AM
01/11/10 09:56 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Now that's what I looking for, current build is already a Tall Alum 360 Alum mopar Block, which forces a dry sump, W-8 ported heads, then what are the most reliable endurance valves for turbo builds, max bore up to 4.180", need to decide stroke/cubes (low end is not critical, throttle response is more so), forged crank or is billet better/needed choice, I would rather limit rpms to keep reliability, rod size 2.1,2.0,1.88?, Ti rods are a consideration, roller is a definite, turbo is of course most obvious choice, but single vs dual turbos, intercooler just makes sense, but thought just maybe a Procharger type set-up might be more reliable to set-up and maintain for someone like me that knows just enough to get in trouble. As tough as it might be to finally put this package together, I am not in a position to be able to afford scattering it, hence reliability is of key importatnce in the chase for 1000 hp.
Re: What build would make the most RELIABLE 1000hp SB? [Re: jcc] #579330
01/11/10 09:59 AM
01/11/10 09:59 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I'd go with a Procharger.
Re: What build would make the most RELIABLE 1000hp SB? [Re: jcc] #579331
01/11/10 10:10 AM
01/11/10 10:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I wouldnt go the Procharger route it uses HP to make
HP where the turbo is basically free... valves...
a good stainless valve is plenty... no need for a
Ti rod... your not spinning it hard.... a chevy rod
size is fine.
It sounds like you would need to get the turbo setup
tuned for you but there are plenty of shops that can
put it on a dyno and take care of that for you
Re: What build would make the most RELIABLE 1000hp SB? [Re: MR_P_BODY] #579332
01/11/10 10:26 AM
01/11/10 10:26 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
size is fine.
Free....
Re: What build would make the most RELIABLE 1000hp SB? [Re: emarine01] #579333
01/11/10 10:29 AM
01/11/10 10:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
size is fine.
Free....
Notice that word "basically"
Re: What build would make the most RELIABLE 1000hp SB? [Re: MR_P_BODY] #579334
01/11/10 10:39 AM
01/11/10 10:39 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Got ya , Hey I was only thinkin
Re: What build would make the most RELIABLE 1000hp SB? [Re: emarine01] #579335
01/11/10 10:45 AM
01/11/10 10:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... thinkin a good thing
Re: What build would make the most RELIABLE 1000hp SB? [Re: MR_P_BODY] #579336
01/11/10 11:10 AM
01/11/10 11:10 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Your looking for Mike Zacardi's Duster - built by SDCE.
http://www.youtube.com/watch?v=tk0FAlRznic
http://www.youtube.com/watch?v=ahMgOG4Bpcw
He had a prochager and just went to a twin turbo setup - both F/I
Post deleted by Defbob [Re: MR_P_BODY] #579337
01/11/10 11:13 AM
01/11/10 11:13 AM
Re: What build would make the most RELIABLE 1000hp SB? #579338
01/12/10 12:20 AM
01/12/10 12:20 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Im fixing to turbo my SB and the turbo set up Im getting will support 900-1000 hp. Course, my stock block won't handle that so I am shooting for 650 hp for now. This is with blow through, pump gas, Eddy heads, .224 duration hydrualic roller, Air to Air intercooler and I believe a 68 mm turbo.
My primary concern to the turbo builder was to make sure it is 100% streetable. He even told me to gear down to 3.54 with the 30" tires!
Re: What build would make the most RELIABLE 1000hp SB? [Re: jcc] #579339
01/12/10 10:19 AM
01/12/10 10:19 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Buy a clean, used W8 or P5 comp eliminator motor and put a longer arm in it.
8.30's @3400 lbs
Re: What build would make the most RELIABLE 1000hp SB? [Re: Mike Swann] #579340
01/12/10 11:35 AM
01/12/10 11:35 AM
Mid-Ohio
Bakaruda432 Offline
mopar addict
Bakaruda432  Offline
mopar addict
Mid-Ohio
All things equal R-3 Block .060 over 340 bore 3.58 crank single plane intake 850 carb does the Turbo option always trump the Procharger?
