73 RR door handles #574155
01/05/10 08:15 PM
01/05/10 08:15 PM
oklahoma
forphorty Offline OP
oklahoma
Does anyone know of a good source for 73 RR outer door handles?
Re: 73 RR door handles [Re: forphorty] #574156
01/05/10 08:20 PM
01/05/10 08:20 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
B E and A (ad at the bottom of the screen)
http://www.beaparts.com/list_items.aspx?body=B&cat=E&subcat=26
While I personally have not used them, they should be good and others highly recommend BEA.
DO NOT use later model B Body ones or generic reproductions (i.e. F Body ones). They will not fit right. DAMHIK!
Common sense is a flower that does not grow in everybody's garden
Re: 73 RR door handles [Re: Ron_M] #574157
01/05/10 08:37 PM
01/05/10 08:37 PM
oklahoma
oklahoma
thanks!
Re: 73 RR door handles [Re: Ron_M] #574158
01/05/10 11:19 PM
01/05/10 11:19 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
I'm askin'! what is the difference? They sure look the same I have handled both, but not compared them side by side...
Re: 73 RR door handles [Re: nomore65BelvJim] #574159
01/05/10 11:37 PM
01/05/10 11:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The "cheapie" repros like to dig into the door skin when you pull up on them,....not nice if you didn't fit them prior to new paint!,....and if you did fit them prior to paint, you had to make the desicion as to wether you ground dowm the interference, or rechromed your originals,....hopefully Mike Ross's (BEA Parts) don't have this issuse either,.....but like anything that wasn't original to the car in question, it should be test fitted prior to paint/final install
Mike
Re: 73 RR door handles [Re: nomore65BelvJim] #574160
01/06/10 09:46 AM
01/06/10 09:46 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
RE: Later B bodies - I tried using some from a 77 Fury and they didn't look right. They stuck out too far. The F Body ones had a recessed(?) area on the handle and were not right either IIRC.
Re: 73 RR door handles [Re: Ron_M] #574161
01/07/10 12:50 PM
01/07/10 12:50 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
the problem with later models is the rod hole location sits in different point/height at handle.
Latch can be adjusted though( there is a provision for that on door ), but dunno if will be enough.
beside that I'm not aware about some exterior physical difference
Re: 73 RR door handles [Re: NachoRT74] #574162
01/07/10 01:43 PM
01/07/10 01:43 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Makes sense considering the design of the later model doors. I found some decent used ones and went with them. Making the later ones work would have been too much trial and error plus sticking my arm up in the door shell gets old real quick.
