The "cheapie" repros like to dig into the door skin when you pull up on them,....not nice if you didn't fit them prior to new paint!,....and if you did fit them prior to paint, you had to make the desicion as to wether you ground dowm the interference, or rechromed your originals,....hopefully Mike Ross's (BEA Parts) don't have this issuse either,.....but like anything that wasn't original to the car in question, it should be test fitted prior to paint/final install
Mike
