Re: 73 RR door handles
[Re: forphorty]
#574156
01/05/10 08:20 PM
01/05/10 08:20 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
B E and A (ad at the bottom of the screen) http://www.beaparts.com/list_items.aspx?body=B&cat=E&subcat=26While I personally have not used them, they should be good and others highly recommend BEA. DO NOT use later model B Body ones or generic reproductions (i.e. F Body ones). They will not fit right. DAMHIK!
Common sense is a flower that does not grow in everybody's garden
[Re: Ron_M]
#574158
01/05/10 11:19 PM
01/05/10 11:19 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
I'm askin'! what is the difference? They sure look the same I have handled both, but not compared them side by side...
[Re: nomore65BelvJim]
#574160
01/06/10 09:46 AM
01/06/10 09:46 AM
Ron_M
Connecticut
RE: Later B bodies - I tried using some from a 77 Fury and they didn't look right. They stuck out too far. The F Body ones had a recessed(?) area on the handle and were not right either IIRC.
[Re: Ron_M]
#574161
01/07/10 12:50 PM
01/07/10 12:50 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
the problem with later models is the rod hole location sits in different point/height at handle.
Latch can be adjusted though( there is a provision for that on door ), but dunno if will be enough.
beside that I'm not aware about some exterior physical difference
[Re: NachoRT74]
#574162
01/07/10 01:43 PM
01/07/10 01:43 PM
Ron_M
Connecticut
Makes sense considering the design of the later model doors. I found some decent used ones and went with them. Making the later ones work would have been too much trial and error plus sticking my arm up in the door shell gets old real quick.
