Page 2 of 3 1 2 3
Re: Brewer Heads [Re: B5 Bee] #532642
12/15/09 12:12 AM
12/15/09 12:12 AM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
Fred made AMC heads years before he made the Mopar heads.
Nope --the first set actually run were Mopar castings
The core boxes were at a foundry in Texas and were destroyed several years ago
Re: Brewer Heads [Re: hemiiroc] #532643
12/15/09 11:02 AM
12/15/09 11:02 AM
gregsdart Offline
gregsdart  Offline
Daytona5812 ,Vern, runs a set on a 604 with duel dominators, goes 7.80s or better last I heard in a 2500 lb Daytona. Motor dynoed over 1100 hp at Lance Lines dyno(Jasons brother).
Re: Brewer Heads [Re: gregsdart] #532644
12/15/09 11:09 AM
12/15/09 11:09 AM
gregsdart Offline
gregsdart  Offline
Just found the dyno post;
As most of you know, my last dyno session ended in disaster. Well, it's been a long road back,{ 1 year}, & I finally got the new motor done. Last motor was a 572. This time I went to a 606 cu in.
Went to the dyno today, & things turned out alot better. I'm so happy I could scream. I was hoping for 1020-1050 hp.
What I got was 1124 hp at 7200 & 902 tq at 5700.
Can't wait till summer. Vern!!!
Also found his last run stats; 1800DA, headwind, 175 mph at 7.86
Re: Brewer Heads [Re: moderncylinder] #532645
12/25/10 06:09 PM
12/25/10 06:09 PM
usa,pa
jkwedge540 Offline
jkwedge540  Offline
usa,pa
what would you need to start making these heads again. I can get a set of these heads that have just been cleaned up?
Re: Brewer Heads [Re: jkwedge540] #532646
12/25/10 06:39 PM
12/25/10 06:39 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: Brewer Heads [Re: moparniac] #532647
12/25/10 11:17 PM
12/25/10 11:17 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
get'm while there hot!
http://www.racingjunk.com/category/1283/Heads/post/2025258/Brewer-Big-Block-MoPar-Heads.html
Id like to see them. I might cal tomarrow and see what the deal is, and what it takes to buy them. Id like to check them out personally. I heard they can have many casting issue's as well as other problems.
By Virgin, I wonder if that means No port work? I would like that if that haven't been ground on. I would send them to Modern pick up a World Block before they dry up. Build a 540-572 inches with 15:1 on alky and try to run 6's. What rocker choices do we have? Anyone know any specifics on valve locations/angles?
Re: Brewer Heads [Re: Bob_Coomer] #532648
12/26/10 02:21 AM
12/26/10 02:21 AM
Milledgeville, (central) Georg...
Bighead440 Offline
Bighead440  Offline
I actually have two sets of Brewers and have run neither set. One set is some of the last cast by FBS and have the late logo and better casting quality. The other set, which I want to try first, is older and has had some pushrod tunnel milling (drilling?) that went through to the intake ports. I think someone was trying to set them up for use with a flat tappet cam or non-offset roller lifters and had to relieve the holes, or maybe they used a rocker with inadequate offset. I have one new set of valves (almost 7" long), the low-block intake, and dedicated spray-bar valve covers. This is encouraging news about the CNC program, maybe I'll get the tunnels/port walls welded and send them in. How much for the CNCing??? RB
Re: Brewer Heads [Re: Bighead440] #532649
12/27/10 07:06 PM
12/27/10 07:06 PM
Oklahoma
68dart500 Offline
68dart500  Offline
Oklahoma
http://predatorheads.com/
I believe this Company has the old Fred Brewer head now.
Re: Brewer Heads [Re: 68dart500] #532650
12/27/10 07:44 PM
12/27/10 07:44 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Predators have splayed valves, Brewers do not.
Re: Brewer Heads [Re: B1Fish540] #532651
12/28/10 04:08 PM
12/28/10 04:08 PM
Oklahoma
68dart500 Offline
68dart500  Offline
Oklahoma
My bad your right this are not the brewer heads
Talk to one of Freds friend today, He thought that Fred had one set left and a place in OKC has a set for sale,that never been run.
Re: Brewer Heads [Re: 68dart500] #532652
12/28/10 05:46 PM
12/28/10 05:46 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I always wondered why nobody bought Freds stuff and brought them back...great head! Ony the B1-PSO comes close but the Brewer is still best.
Re: Brewer Heads [Re: B1Fish540] #532653
12/28/10 07:08 PM
12/28/10 07:08 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Well indy owns predator now so just wait for the new Freindys to come out!
Mopar Performance
Re: Brewer Heads [Re: moparniac] #532654
12/29/10 09:11 PM
12/29/10 09:11 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: Brewer Heads [Re: moparniac] #532655
12/30/10 12:22 AM
12/30/10 12:22 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
I don't see why some one would buy a ultra rare exclusive head that has known casting problems and little tech support ? The Brewer head flows slightly better than the old tried and true workhorse original ported B1.
The B1 and the Brewer are close to 20 year old cylinder head technology.
Here is the B1 next to the Predator head.
The predator next to a RPM head
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Brewer Heads [Re: go green] #532656
12/30/10 10:06 AM
12/30/10 10:06 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
$$$ would affect most peoples buying decision. No doubt the predator is a better head but it also has the price tag to go along with it. Deff. out of my budget and most people I know.
One day I will have something cool here.
Re: Brewer Heads [Re: go green] #532657
12/30/10 11:46 AM
12/30/10 11:46 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
yep, the Predator is the best head currently available for the BB mopar unless you include the Stage V Millenium head, which I believe flows better. But compare those to a Big Chief head or a Thor head and the Predator pails, its the best we have...but it's still just an "entry level" head compared to the Brand X offerings.
Re: Brewer Heads [Re: sdaurity] #532658
12/30/10 11:53 AM
12/30/10 11:53 AM
Illinois
Hurst390 Offline
Hurst390  Offline
Illinois
This guy was supposed to be working on making billet versions of the Brewer Head..You might want to get in touch with him and see how it's going..
http://www.jpmagazine.com/jeepshots/sideways/154_1101_january_2011_sideways/index.html
here is an AMC Pro Stock head..last revision
80 AMX Barry Allen 420 AMC Iron Heads Jerico 4-speed Advanced clutch 2950# street legal 5.97 115.73 Coles county dragway 10/28/07 9.42 142.96 best in 08(6.00 115.8 1/8) 5.97 116.2 in 09 http://www.youtube.com/watch?v=AXSr201-tmA
Re: Brewer Heads [Re: Hurst390] #532659
12/30/10 04:11 PM
12/30/10 04:11 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Looks good to me! And 2500 HP with no teardowns is pretty impressive.
Re: Brewer Heads [Re: B1Fish540] #532660
12/30/10 04:34 PM
12/30/10 04:34 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Entry level, really? I'm not thinking there's anything entry level about the Predator or the PSO. What do the Big Chief and Thor flow, or more importantly, what power do they make? I see the Chevy guys running blowers and NOS just to make a 7.20 bump in T/D too, so I'm not sure what you are basing your comments on.
Re: Brewer Heads [Re: camastomcat] #532661
12/30/10 06:09 PM
12/30/10 06:09 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Its not that this is'nt a great head, it is, but it will only get you in the show, at best. This is only because of the small 4.8 bore space mopar block limitation. Both the Thor and best Big Chief can use a 2.5+ intake valve...translates into about a 30/40 CFM advantage. The same applies with this Brodix head:
http://www.brodix.com/heads/pb2005.html
Page 2 of 3 1 2 3
