Patching a slick, anyone have any experiance?
#467961
09/14/09 01:38 PM
09/14/09 01:38 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I got a small hole in one of my Goodyear 14x32 slicks this weekend. It's about 1/3 of the way in from the edge or from the center. I used a pug that I had in the trailer, cut it off flush with the tire surface. Then I did a big burn out to see if it would hold and then just drove easy down the track and it held just fine. So I went ahead and raced with it keeping my eye on it each burn out.
I made about 5 passes before I lost so now I'm trying to figure out if I can patch it and use it the rest of the year and how others have done it.
I've heard of some of the tire shops have a plug/patch that plugs the hole and patches the tire on the inside and I would think that would be best.
I've spoke to a friend of mine who has plugged 2 of his slicks and ran them the until they wore out and never had a problem.
So I'm looking for input from guys that have experiance with patching a slick so I'll have a better idea what to do next. I really don't want to have to buy new slicks, they only have about 50 passes and I'd have to buy 2 so they would match so I really don't want to go that round if I don't have to.
I also don't want to hear just opinions, I want to hear from people who've had experience, 1st or 2nd hand. I know the safest thing is to replace them but I don't think that's necessary.
Thanks in advance..
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Patching a slick, anyone have any experiance?
[Re: WadeMetzinger]
#467962
09/14/09 01:40 PM
09/14/09 01:40 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I plugged a slick once and never had an issue with it. Used it until it wore out. An inner patch would be better, but a plug will work. CHIP
[Re: WadeMetzinger]
#467964
09/14/09 01:52 PM
09/14/09 01:52 PM
Challenger 1
Cincinnati, Ohio
Thanks in advance..
Replace it, sorry. You are going too fast to race on a patch. Slicks are very thin, how could you plug it? I have had no luck patching it years ago, your tires get pretty hot during burnouts which doesn't useally happen with street tires. Sorry
[Re: Challenger 1]
#467966
09/14/09 02:19 PM
09/14/09 02:19 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
My M/T frontrunner has a patch in it, but I have never had to patch a slick. Have a tube with a couple of patches on it. If you patch it just dismount it and get a scotch brite pad on a angle gringer and rough up the area to patch. Glue it down and press out all the air under the patch. It should hold all day for you.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: MegaDart]
#467969
09/14/09 02:58 PM
09/14/09 02:58 PM
Posts: 1,898 Milwaukee WI
R_Blaha
Milwaukee WI
why wouldn't you just put a tube in there and you wouldn't have to worry about a patch or your safety?
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT 1969 Dodge Superbee post coupe 383 1969 Dodge Superbee hardtop 472 hemi 1989 Mustang GT 1993 mustang lx 5.0 2004 screaming yellow cobra 2013 CVO Roadglide
