Patching a slick, anyone have any experiance? #467961
09/14/09 01:38 PM
09/14/09 01:38 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I got a small hole in one of my Goodyear 14x32 slicks this weekend. It's about 1/3 of the way in from the edge or from the center. I used a pug that I had in the trailer, cut it off flush with the tire surface. Then I did a big burn out to see if it would hold and then just drove easy down the track and it held just fine. So I went ahead and raced with it keeping my eye on it each burn out.
I made about 5 passes before I lost so now I'm trying to figure out if I can patch it and use it the rest of the year and how others have done it.
I've heard of some of the tire shops have a plug/patch that plugs the hole and patches the tire on the inside and I would think that would be best.
I've spoke to a friend of mine who has plugged 2 of his slicks and ran them the until they wore out and never had a problem.
So I'm looking for input from guys that have experiance with patching a slick so I'll have a better idea what to do next. I really don't want to have to buy new slicks, they only have about 50 passes and I'd have to buy 2 so they would match so I really don't want to go that round if I don't have to.
I also don't want to hear just opinions, I want to hear from people who've had experience, 1st or 2nd hand. I know the safest thing is to replace them but I don't think that's necessary.
Thanks in advance..
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Patching a slick, anyone have any experiance? [Re: WadeMetzinger] #467962
09/14/09 01:40 PM
09/14/09 01:40 PM
an8sec70cuda Offline
I plugged a slick once and never had an issue with it. Used it until it wore out. An inner patch would be better, but a plug will work. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Patching a slick, anyone have any experiance? [Re: an8sec70cuda] #467963
09/14/09 01:49 PM
09/14/09 01:49 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I've had to plug several sets of slicks and the plugs have always held without a problem.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Patching a slick, anyone have any experiance? [Re: WadeMetzinger] #467964
09/14/09 01:52 PM
09/14/09 01:52 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks in advance..
Replace it, sorry. You are going too fast to race on a patch. Slicks are very thin, how could you plug it? I have had no luck patching it years ago, your tires get pretty hot during burnouts which doesn't useally happen with street tires. Sorry
Re: Patching a slick, anyone have any experiance? [Re: WadeMetzinger] #467965
09/14/09 02:15 PM
09/14/09 02:15 PM
Az
Crizila Offline
Crizila  Offline
Az
Thanks in advance..
Plug patch is the way to go.
Fastest 300
Re: Patching a slick, anyone have any experiance? [Re: Challenger 1] #467966
09/14/09 02:19 PM
09/14/09 02:19 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
My M/T frontrunner has a patch in it, but I have never had to patch a slick. Have a tube with a couple of patches on it. If you patch it just dismount it and get a scotch brite pad on a angle gringer and rough up the area to patch. Glue it down and press out all the air under the patch. It should hold all day for you.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Patching a slick, anyone have any experiance? [Re: WadeMetzinger] #467967
09/14/09 02:31 PM
09/14/09 02:31 PM
Long Island, NY
B1Ken Offline
B1Ken  Offline
Long Island, NY
I had a fire extinguisher pin go through my Good Year slick after I won a round on Saturday night at an E-Town National event. Didn't know it until we opened the trailer the next day. The guy I beat the night before gave me a plug to fix it. It worked O.K. but we put a patch inside after the race and it stayed there until the tire wore out.
Re: Patching a slick, anyone have any experiance? [Re: B1Ken] #467968
09/14/09 02:37 PM
09/14/09 02:37 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I have patched them from the inside. Use a die grinder and grind/clean all the rubber around the hole. Put the cement on and lite it on fire, blow it out and apply patch. Mine has held great for over a year, 160mph+ 1.18 60'.
Re: Patching a slick, anyone have any experiance? [Re: MegaDart] #467969
09/14/09 02:58 PM
09/14/09 02:58 PM
Milwaukee WI
R_Blaha Offline
R_Blaha  Offline
Milwaukee WI
why wouldn't you just put a tube in there and you wouldn't have to worry about a patch or your safety?
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: Patching a slick, anyone have any experiance? [Re: WadeMetzinger] #467970
09/14/09 03:16 PM
09/14/09 03:16 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Like several of the other guys have done, I've put a plug in one and ran it that way until the tire wore out, without any problems.
Re: Patching a slick, anyone have any experiance? [Re: super451b] #467971
09/14/09 03:25 PM
09/14/09 03:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Depends on how large and damaging the hole is.It has been done with success.I would rather check the inside of the tire to see if any chords are unravelled first then decide.
Re: Patching a slick, anyone have any experiance? [Re: WadeMetzinger] #467972
09/14/09 04:34 PM
09/14/09 04:34 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
I have plugged 4 slicks, never an issue.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
