Just purchased Hurst Comp Plus shifter for install... #465768
09/11/09 05:17 PM
09/11/09 05:17 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I just brought a complete Hurst Competition Plus shifter and install kit for my 70 Charger R/T. It will replace the sloppy abused shift mechanism that doesnt have detents in it.
You guys who run 4speeds have any tips for improving the shift quality with one of these shifters?
Re: Just purchased Hurst Comp Plus shifter for install... [Re: Blakcharger440] #465769
09/11/09 05:35 PM
09/11/09 05:35 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
I bought a new one in the spring and hated it. I had an old "sloppy" one that I welded uo the shifter rod holes and moved 'em up .300" to shorten the throw. I love it,NEVER miss a shift. sometimes sloppy is better.
Re: Just purchased Hurst Comp Plus shifter for install... [Re: Bill MeLater] #465770
09/11/09 05:40 PM
09/11/09 05:40 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
moved them UP ??? Hurst LOWERED the holes to shorten the throw for the 70 B body pistol grip ???
Re: Just purchased Hurst Comp Plus shifter for install... [Re: JohnRR] #465771
09/11/09 05:51 PM
09/11/09 05:51 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Longer lower arm equals shorters throw on the handle, not the other way (like John said).
Re: Just purchased Hurst Comp Plus shifter for install... [Re: JohnRR] #465772
09/11/09 06:39 PM
09/11/09 06:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, '70 is on the right, '68-'69 on the left.
Re: Just purchased Hurst Comp Plus shifter for install... [Re: John_Kunkel] #465773
09/11/09 07:48 PM
09/11/09 07:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Get a pack of Hurst clips and washers for it.I installed them in my 65 and couldnt believe how it tightened up the shifts.Rocky
Chrysler Firepower
Re: Just purchased Hurst Comp Plus shifter for install... [Re: therocks] #465774
09/11/09 08:24 PM
09/11/09 08:24 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Make your own rods out of 1/2" steel with teflon raced ball joints at both ends.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Just purchased Hurst Comp Plus shifter for install... [Re: Jim_Lusk] #465775
09/11/09 10:39 PM
09/11/09 10:39 PM
Wisconsin USA
Wisconsin USA
My knuckles disagree. Real world says whatever I did works for me. Anyone interested in an almost new competition plus?
Re: Just purchased Hurst Comp Plus shifter for install... [Re: Bill MeLater] #465776
09/11/09 10:47 PM
09/11/09 10:47 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Call Brewers Perf. They sell Shifter Linkage Levers that will shorten the throw or make your own.
https://board.moparts.org/ubbthreads/show...rue#Post4111971
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Just purchased Hurst Comp Plus shifter for install... [Re: 70sixpkrt] #465777
09/12/09 08:06 AM
09/12/09 08:06 AM
Wichita,KS
Wichita,KS
Well the new shifter I purchased from Summit Racing looks exactly like my old sloppy shifter...even has the same part#
The new one has the short levers just like my old one does which I have found out through this thread is not original to my 70 Charger RT 4speed car...so the new one must also be a reproduction of the 69 Bbody type shift mechanism
The new one does have the positive stops already on it though.
I will call Brewers to get a set of those modified shift levers as I sure would like a shorter pattern for shifting!
Re: Just purchased Hurst Comp Plus shifter for install... [Re: Blakcharger440] #465778
09/12/09 09:58 AM
09/12/09 09:58 AM
Wisconsin USA
Wisconsin USA
Forgot to mention the install kit is junk too. Best to make your own rods and keys, that way they will be stiff/not sloppy and you can adjust the ratio/throw as needed. Only expensive part is the rod ends..
Re: Just purchased Hurst Comp Plus shifter for install... [Re: Blakcharger440] #465779
09/12/09 11:10 AM
09/12/09 11:10 AM
JohnRR Offline
JohnRR  Offline
What type of shifter do you have , pistol grip ? If so you need the one in the picture above with the LONGER levers to SHORTEN the throw . If you are comparing the sloppy feel to a NEW cars shifter feel , a trans with an INTERNAL SHIFT RAIL ... DON'T , you'll NEVER get that feel ...
Re: Just purchased Hurst Comp Plus shifter for install... [Re: Blakcharger440] #465780
09/12/09 11:28 AM
09/12/09 11:28 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Just last summer we had the 68 Runner Hurst
all rebuilt with new parts and got rid of the
old ball shifter and stick. The new Pistol Grip
and stick was over $225 from Hurst. After looking
all over the place for one, the guy right down the road
had the factory Hurst Pistol Grip and
stick hanging on the shop wall. For $150 we
thought it was a deal. He switched over to a V gate.
With some new arms and steel bushings in the new
pit pack, the Pistol Grip shifts super tight.
Now speed shifting is a lot more easy.
Snap your neck, mega G-force launch, is all I want!
Re: Just purchased Hurst Comp Plus shifter for install... [Re: JohnRR] #465781
09/12/09 11:38 AM
09/12/09 11:38 AM
Wichita,KS
Wichita,KS
what type of shifter do you have , pistol grip ? if so you need the one in the picture abaove wit hthe LONGER levers to SHORTEN the throw . If you are comparing the sloppy feel to a NEW CARs shifter feel , a trans wit han INTERNAL SHIFT RAIL ... DON'T , you'll NEVER get that feel ...
I have the pistolgrip shifter and the round ball shifter that came in the kit.
I did see the pic above of the mechanism with the longer levers....but I thought that those modified levers from Brewers would help shorten the throw?
Since I probably will not be able to find an original 70 pistol grip shifter mechanism that is in good shape...thats why I purchased the new shifter then I could just use those small levers from Brewers?
Re: Just purchased Hurst Comp Plus shifter for install... [Re: JohnRR] #465782
09/12/09 04:19 PM
09/12/09 04:19 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Ahhh, wouldn't say that....
My old cuda had a brandy new Comp Plus shifter box (the B body one they sell) with my own 1/2 steel shift rods with zero slop rod ends, on a ball detent side cover. I swapped out the A833 for a tremec TKO600 with the internal rail shifter (not with the keisler or other offset linkage) and was kinda disappointed. Wasn't as "solid" as the A833 setup I had on before.
The Challenger I have now has the same setup. Beautiful.
Re: Just purchased Hurst Comp Plus shifter for install... [Re: Blakcharger440] #465783
09/12/09 09:39 PM
09/12/09 09:39 PM
JohnRR Offline
JohnRR  Offline
Call Brewer , he MIGHT have one of those shifter boxes , or Passon , but it won't be cheap without a core .
Re: Just purchased Hurst Comp Plus shifter for install... [Re: CJK440] #465784
09/12/09 09:41 PM
09/12/09 09:41 PM
JohnRR Offline
JohnRR  Offline
Not everyone is as handy as you ... or the guy that the laws of psyhics don't apply to ...
Re: Just purchased Hurst Comp Plus shifter for install... [Re: JohnRR] #465785
09/12/09 11:20 PM
09/12/09 11:20 PM
Wichita,KS
Wichita,KS
Well I installed the shifter and.....it seems the shift pattern is alot tighter than the other worn out one. Maybe the other shifter is just very used and worn.
I will take it out again tomorrow for a longer drive but it seems that the new shift mechanism has a very short pattern and I dont know if I want it any smaller than it is.
I test it more and see how it goes. Thanks for the input guys and will post back on how it went!
Re: Just purchased Hurst Comp Plus shifter for install... [Re: Blakcharger440] #465786
09/13/09 05:55 AM
09/13/09 05:55 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
The mechanism with the longer legs is what you want for that really short throw. I have set this up for a lot of guys over the years in just about any Mopar and a bunch of Chevys and Fords too. That mech. with the 890 and 891 side levers makes for the shortest throw there is. I have a few of the mechanisms, bolt in or slip in handle if your interested, good luck.
Re: Just purchased Hurst Comp Plus shifter for install... [Re: tecmopar] #465787
09/13/09 03:29 PM
09/13/09 03:29 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
We have new 1970 B-body mechanisms in stock:
http://www.brewersperformance.com/proddetail.asp?prod=SM%2DBOLT%2D70B
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
